Question about Panasonic NN-P295SF Microwave Oven
Panasonic nnst556m when it turn on after 5 sec it
Panasonic microwave owen nnst556m when it turn on after 5 sec it goes off why?
    President:
  • 3,433 Answers
Turn timer to 15 seconds, make sure there is s cup of water in it. Then time the timer to see if it is out of whack.
Posted on Jun 22, 2009
Hello i do not have the instruction for my bread maker. where can i get another copy. thanks
/turn it on 4-5 sec it shuts down display still lites unpluged for a min. tryed again same thing
Dec 07, 2010 | Panasonic NN-T993SF Microwave Oven
WHAT IS THE MAX TEMPERATURE THIS MODEL CAN SUSTAIN NN-CS599S LET SAY I WANT HEAT THE SUBSTANCE FOR 300 CELCIUS FOR 10 MINUTES..HOWEVER THE OWEN REACH THE SET TEMP AT FIRST 5 MINUTES....IS IT THE OVEN CONT...
I do not know of ANY microwave that will get you anywhere near 300 celcius, the cavity thermals are rated around 110.F and even the mag limit thermal of the comercial units are 300F No where near the celcius temps you are talkig about.
Sep 15, 2017 | Panasonic NN-SN657S Microwave Oven
Panasonic inverter genius sensor 1250w, turns on for about 3 sec. then goes off, no codes.
try locating the primary door sensor. this is probably burned. replace the door sensor with appropriate amp rating - usually 16A (or higher) 123vac
Feb 09, 2010 | Panasonic Microwave Ovens
My nnsn977s shuts off 5 secs after started
This is a problem with the "magnetron". The magnetron part number for panasonic is 800-833-9626 worth 45$ approx.
Let us know if you need further assistance.
Thanks for contacting Fixya.com
Jan 14, 2010 | Panasonic NN-T964SF Microwave Oven
Panasonic microwave does not work for more than 3 secs.
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on them.
You can find many Panasonic owner's manuals for free download here.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you're not in the US, see Panasonic.net.
Dec 04, 2009 | Panasonic Microwave Ovens
Comes on for 5 Secs
Hi I am Vortash sounds to me as if the Magnetron is burning out and the heat sensor switch is turning the unit off as the mag gets hot ? .. you can get a cheap replacement of ebay but to be honnest microwaves are so cheap now you will probably get an oven for what you would pay for a new magnetron .. Regards Vortash
May 20, 2009 | Panasonic NN-S262SF Microwave Oven
Turns off after 3 sec
Usually this indicates failure of the magnetron and/or the inverter. Neither is easy to test without specialised HV equipment. Often the cause is operating the oven without anything in it. If this has happened, it will generally be failure of the magnetron.
Replacement of the magnetron is relatively easy (about 15 minutes) and the inverter a little longer but if you do not have the knowledge/skills please do not do it - there are very dangerous (deadly) voltages associated with magnetrons even after they have been switched off.
Cost of magnetrons ranges upwards from USD25 to USD100 (from Panasonic spare parts) and inverters range upwards from USD125. The cost of parts is often the reason microwave ovens are not repaired.
Doug
Nov 05, 2008 | Panasonic NN-T990SA Microwave Oven
Panasonic NN- S760BA heating problems
Chances are it has a bad magnetron. If you decide to have it serviced, I would definitely recommend that you contact a servicer who is authorized by Panasonic. You can find them here: http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001 Good luck.
Feb 20, 2007 | Panasonic NN-S762 Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
360 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
