Question about Mitsubishi WT-42311 42" Rear Projection Television
Green and red shadows
The screen looks like it has double vision with red and green shadow. All lamps are lit not sure what problem is. Tv worked fine when turned off . When it was turned back on picture problem was there. when changing inputs the words are doubled in red and green .
  • hjolles775 Jun 22, 2009
    I had already tried the convergance reset. That did not work. Is the convergance part easy to repair And do you know the approximate cost for the part.?
    Thanks for the help I will try the part to see how it works. Is there more than one of them . And were is it locaated in the TV.
    Thanks for the advise and the quick response. Your site is very helpful. .
  • 583 Answers
The problem is the projectors are off balance, open your menu with your remote and go to convergence, once there click auto and it should readjust itself,this will solve the shadowing issue. if that doesnt work then the covergence is gone faulty,you ll have to get the convergence replaced or repaired by a tech.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jun 22, 2009
  • livetech Jun 22, 2009
    its easy to repair for a tech but not for a nontechnical personso getting it repaired by tech is advisable.
    it should cost approx 120 dollars for part if replacement necessary -plus service charge.
My tv looks like it has double screen....for example a picture of a tree....right next to it would be another tree....double vision...
This is not a LCD tv,It a DLP tv.This tv have a problems known as Convergence problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board must be change to fixes 3D pictures,shadows colors pictures and Green,Blue,Red colors misaligns,don't matches up to form a good picture.The shop will u $300-350 for parts and labors.
May 24, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Panasonic Rear Projection Screen TV
you need new convergence chips, there are 2, part number stk 392-110, also you must check for burnt resistors, if you don't have very good soldering skills at least, you will need a tv repairman.
Sep 15, 2009 | Panasonic PT-53WX42 53" Rear Projection...
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Shadows double vision
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
Apr 19, 2009 | Hitachi 50FX30B 50" Rear Projection...
Red shadow?
call a tech and have them converge the tv.its either that or the focus
Jan 02, 2009 | Pioneer PRO-119 60" Rear Projection...
Blurred TV - double vision with red hue
I was searching online about what could be the problem with our TV and I came across your page. We have a 52" JVC Projection TV that now has a "blurred" screen. We can see the channels but it looks like it's has a shadow around the images. The screen in in a red hue with green blur.
If you have any suggestions on what caused this and what we can do to have this fixed, I would greatly appreciate your advice.
Sep 07, 2008 | JVC AV-56WP74 56" Rear Projection...
Double vision
You need to replace the two convergence ICs they are STK392-110 you can get replacements at the following link with fre installation instructions.
http://servicemanuals.vstore.ca/
Aug 19, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blue shadow and lines
This would apear to be a convergence issue ..sometimes you can go into settings and converge it manualy.. if this is to far out of range. a service tech will have to adjust inservice mode. if the convergence cuircits are not failing. if so then there are cuircits that will have to be replaced. is this just a blue shadow?.. is there green or red shadows. if not it may not be a major repair.
Dec 18, 2007 | Samsung HCN653W 65" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
