Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Frigidaire dishwasher sounds funny and arms turn slowly
When the initial water fill is done, the unit makes a different sound than the splashy sound it usually makes. I opened the door to check the arms and they were barely spinning at all.
    Sergeant:
    Champion:
  • 208 Answers
Worn internal parts repare or replace
Posted on Jun 22, 2009
Upper wash arms of dishwasher don't get water
I know this will sound funny but, you will have to trust me on this one. Try running some orange tang juice crystals through it. Your machine will sparkle after words. Hope this helps!
May 09, 2013 | Frigidaire Dishwashers
Frigidaire gallery prof series dishwasher- arms dont work
Hello - I suggest verifying that there is enough water pressure coming into the unit. Do you noticed if the spray arm is cracked or broken? Will it rotate slowly? If so, you might have to remove and replace the spray arm assemblies.
Oct 05, 2012 | Frigidaire Dishwashers
Ffbd2407lm frigidaire dishwasher stops washing cycle?
Sounds like you need a professional to diagnose the unit for repairs. You are either having a timer issue or a control board communication error.
Aug 24, 2012 | Frigidaire Dishwashers
The Frigidaire pld2855 fills and drains but no water to the spray arms, it also heats very well, any ideas
it sounds like you have a problem with your spray pump it could be clogged up or it may have seized you will have to take it off and have a look at it
Dec 08, 2011 | Frigidaire Dishwashers
Dishwasher not cleaning properly - soap dispenser does not empty. Dishes are not dry
you might have water problem if the unit fill with water but not spray the water all over that can be the problem and it can be fix.
to see if the spray arm is working good - after the unit fill with water and it sound that it start cleaning open it slowly and put the arm in any angle you want then close the door so it can run again , then open again see if it moved .
if it didnt move then ou have a spray unit problem or pump problem , but if it did move look on the spray arm hols you might have food or something got stuck in them, and cleaning them will help .
let me know what you found and i can help you more...
May 23, 2010 | KitchenAid Dishwashers
Apparently no water pressure to upper washing arm.
Hi sounds like there is a blockage in the circulation pump which causes low water pressure as it cannot push the water around. You would have to remove the unit and turn on it's side and remove the circulation pump to clear the blockage.
Also check all the holes in your spray arms for any blockages. Best to remove each arm and clean in the sink. Any blockages causes the arms not to turn.
Jan 24, 2010 | Frigidaire Dishwashers
Dishwasher doesn't seem to be cleaning. Detergent cup opens, but detergent oozes down the inside of the door. Dishwasher is Frigidaire FDB956RBC
More then likely your water is not circulating properly.
Can be a tricky fix, Usually involves turning the unit upside down and replacing the impeller.
Could also be something blocking the jets (Little holes in the Water arms) Poke them with a small toothpick or something small to make sure the water is flowing good threw them.
Most of my experiences it has been the impeller wheel that usually goes bad.
Hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 03, 2009 | Frigidaire FDB956RB Built-in Dishwasher
Dishwasher fills but arms wont spin
sounds like a sticky or broken valve. these units have electronically operated valves to control water flow. its very likely that one of these has failed.
Sep 20, 2009 | Dishwashers
I have a fridgidaire quite 1 built-in dishwasher aprox 10 yrs old . Its not cleaning dishes sounds funny,and soap is staying in dispenser. Have any advice
first check the wash arm ... check the holes in the wash arm . make sure that they are not plugged.
next check that the wash arm is moving . spin it to check that it is free.
next check that there is water pressure to move the wash arm... let me know
Dec 15, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire ultra quiet I dishwasher
Sounds like the water may not be turned on to the dish washer.
The arm spins with water pressure
Oct 16, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
347 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
