Question about LG HBM 730 Bluetooth Headset Wireless Headset
Deprogram bluetooth i need to deprgram my bluetooth so i can connect it to my new phone
    Guru:
  • 395 Answers
Just let it charge for 24 hours and that should reset it and delete the link key.
Posted on Jun 03, 2010
How to connect bluetooth headset to my nokia c5-03 phone
Hi Madhav,
Thank you for your question at Fixya,
The solution to your problem is as follows :-
  • The blue tooth connection depends on the fact as to whether or not the bluetooth handsfree that you have is compatible with your phone or not , a good idea would be to check it before you buy one.
  • Now if you want to connect your bluetooth handsfree to your mobile , you need to first make sure that your phone's bluetooth connection has been switch on and then it's not hidden and it should be in shown to all mode as this is a nokia phone.
  • When you switch on the bluetooth connection in your phone , then you need to switch on your bluetooth handsfree and then keep it on.
  • Then again you need to go back in the bluetooth option and then select search for paired devices option or new paired device option , then the phone will search for available bluetooth connections.
  • If it detects your bluetooth , please accept that connection and then it will ask you for a pass code , which you have to enter as 0000 and then press ok.
  • That's it! you will have your phone successfully connected to your bluetooth handsfree.
Hope that helps ...:) In case you have any queries, feel free to contact me.
Sep 19, 2011 | Motorola Mobility Bluetooth Headset, Mini...
Tip
How to Bluetooth Connect your Phone to your PC.
How do I connect my bluetooth phone with my computer? First you need to turn your phones visibility on. Most phones you do this by going into the menu, settings and they should be an option for "connections." Bluetooth will or should be under your connects, like I said this is for most phones. You need to first make sure your bluetooth is turned on. Next you need to turn on your bluetooth's visability.
As far as your computer goes. You either need a laptop/tower with bluetooth build in or a bluetooth USB adapter. You can generally get a bluetooth USB adapter for less than $30, and these are very useful and can be used with multiple phones, which is great about bluetooth.
After you have your bluetooth USB installed on your computer, then you need to sync them together. The easiest way that I have found to do this is to do it from the phone. Under your bluetooth settings under your phone, they should be an option to search for new devices or to pair it. Once your perform the search it should find your computer. Select to pair it with your computer. It will ask you for the passcode on the phone it should be "0000" that is four zeros. You should get a pop up from the system tray on a windows machine asking if you want to pair your bluetooth with this device. You need to tell it yes and it will *** for the passcode, which again is four zeros "0000." You should then be ready to use your bluetooth enabled phone with your computer.
on Feb 11, 2010 | Cell Phones
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
I am trying to disconnect my bluetooth from my old cell phone and reconnect it to my new cellphone
Unable to connect my new iphone to the bluetooth in my car.
I've turned off the blue tooth in my old phone but it only turns off the bluetooth in the car. I have tried to then reconnect my new iphone, which is searching and showing that it has located the bluetooth (blue tooth flashing in car, shows on the sceen for a second and then turns off with message 'no service' phone off. If I turn on the old phone, everything comes back on.
Any ideas?
Jan 23, 2011 | Motorola Mobility Bluetooth Hands Free...
Have new base station (old one failed) Plroblem , can not program the 5 other field phones to the new base Seems they only want to connect to the old base- even when using the menu to reprogram them ! the...
I think you have to send them back to uniden to deprogram them from the old base. A pain in the neck but I am pretty sure they have to be deprogrammed or they can't get a new base. I know this isn't so helpful but sometimes thats life
May 17, 2010 | Uniden 5.8GHz Dual Cordless Phone
HOW DO I CONNECT MY CEL TO MY LAPTOP VIA BLUETOOTH
Feb 10, 2010 | Cell Phones
I need to connect a new phone to my lexus 460ls bluetooth system
Go into the information /Nav Screen and you will find an icon for phone, then settings. Click on the icon and it it will give you a connect new phone option, click on that icon and it will release a 4 digit entry code and be findable by your phone.
Next go to your phones tools or connections settings and look for Bluetooth, enbale Bluetooth, Search Bluetooth Devices/handsfree Your phone will search out the car, once found it will request the 4 digit pin code to be input and ask you to confirm "handfsree" Once confirmed the car will read out connecting...then bluetooth connection successful and the dial pad will appear on the NAV screen
If you have more than one phone connected to the car the driver will need to select the connect phone button in order to chose the phone he wishes to enable
Jan 17, 2010 | Lexus LS 460 Cars & Trucks
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Dec 14, 2007 | Motorola Mobility RAZR V3
LG HBM 730 Bluetooth Headset Wireless Headset Logo
89 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
coolboyjitu
Level 1 Expert
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
