Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Rear projection set keeps turning off after it warms up
WS-5531 rear projection works fine for about an hour then turns off on its own. I try to turn it back on but it clicks off before the picture comes on. after leaving it off for a half hour it will work for a while again.
  • Larry Martin May 11, 2010
    Not sure of the model. Did some digits get lost? In general, this sounds like an overheating problem. Is the unit in a "cabinet" with restricted air flow? Are all fans working (under lamp and in back) and are all filters cleaned? In a few years, these tv's get just plain dirty...real dirty and need to be cleaned, including REMOVING THE FRONT SCREEN, and cleaning the mirrors below the screen and on the (inside of the) back of the unit. Clean the front two (yes two) screens with a damp (not wet) cloth.
  • 64 Answers
Sounds like thermal overheating. Is the TV in a "cabinet". If so...overheating is likely, Also...if the set is more than a few years old, you should clean all fans and filters (front, side, back) as approprite. Check the lamp and cooling fan...is it dirty? If so...cleaning is needed as inadequate air flow is most likely the culprit.
Posted on Aug 11, 2009
TV keeps turning off & resetting every 15 minutes & up to 10 hours. When it is running the picture is PERFECT & BEAUTIFUL ! Can anyone tell me where to start after the DM Elec. caps ?
WHY DOES IT KEEP TURNING OFF - Fixya
www.asksbook.com/support/t24227796-keep_turning_off
Apr 24, 2014 - These, like most newer tvs have self-checks that shut the tv off if the fault could .... Mitsubishi WS-65511 65" Rear Projection Television Logo ...
[PDF]871D3547B10 (V21 OG) 52 through end.indd - Mitsubishi
https://www.mitsubishi-tv.com/asset/file/owners_guide/WS-55511.pdf
Projection Television Models ... WS-65511 WS-65611 WS-65711 WS-65712 ... which can be determined by turning the equipment off and on, the user is encouraged ...same stationary images on the screen for more than 15% of your total TV
Jan 19, 2016 | Mitsubishi WS-65511 65" Rear Projection...
WS-55311 rear projection turns off on own after an hour
It sounds like the fans used by the manufacturer are either clogged or not moving much air. Have you checked the filters? Is the fan under the lamp working? Is the unit fan (on the rear) turning?...or is it one dirty mess? If so, a good cleaning is in order for both the unit and the fans. It does indeed sound like thermal overload somehow or other.
Jun 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
May 09, 2009 | Televison & Video
Picture won't hold it keeps flipping over and over
look for dry-joints on the guns and convergence boards
Apr 01, 2009 | Mitsubishi WS-55813 55" Rear Projection...
Green light
Green light keeps bleeking and tv won't turn on at all.
Jul 19, 2008 | Mitsubishi WS-65813 65" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Screen blacks out
Check your set for coolant leakage. It is very prevalent on Mits HDreadys.
If your 4 layer Signal board - beneath the blue gun - has coolant on it, you'll have problems finding a replacement. If it's the boards under the other 2 guns, they can always be repaired as they are single layer.
A drip shed should be installed to keep the coolant off your boards.
Mr Bob
Feb 02, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
171 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
