Power comes on and boots up
Sends some sort of message concening HDD then shuts off
  • Traci in Texas May 11, 2010
    What is the message that you get about the Hard Drive ... that will make a big difference in how to fix what is wrong.
    Sniper:
  • 51 Answers
Try to reset you motherboad bios... make sure to unplug the power cord.. remove the bios battery for 10 mins then put it back... and try to switch the jumper setting to "2-3 configure" for a moment and then bring it back to "1-2 normal mode" position..
Posted on Jun 23, 2009
E machines em250 wont boot
what sort of error message does this come with?
or does it just fail to load the OS, if so it might be a case of reinstalling windows (if you use that)
to make sure you don't loose your files build a knoppix live CD/DVD/USB (plenty of guides to help you with this) once you've done this go into the BIOS and change the boot order to whatever media you have it installed on to first so lets say USB it will look sort of like
1. USB
2. HDD
3. CD/DVD
4. Network Boot
so once it boots navigate to the HDD and you should be able to access all files now just begin copying the ones you want to keep
Dec 22, 2013 | Acer eMachines eM2501162 Netbook
My laptop has. Crash while I was downloading a program now when I try to restart,it comes with error to reboot,inset system disk, i. reinsert the disk that there,but same thing comes up. Also took disk...
The HDD password is a BIOS function. A password is set and passed to the HDD. Then the BIOS on power up sends the password to the HDD and unlocks it on each boot. It could be your HDD is dead and so when BIOS sends pwd to HDD there is no response.Try BIOS reset to defaults
Jan 06, 2012 | Computers & Internet
When I start the machine it is only showing mother board name further it is nor processing also no cursor coming
Your system is not booting
You remove all HDD/ DVD/and any other device
Power on with only mother board,
It will initialise all and rest with a message "BOOT FAILURE"
It means the M/B is good
Then connect the HDD and power on.
If not proced then try to re-load the operating system.
please vote for me if your problem sort out .
Let me know
Alex
May 21, 2011 | Mercury P4VM800M7 Motherboard
Wont boot
In that case, looks like you have a faulty motherboard (video chip) chip-set. Remove motherboard from the casing and apply thermal paste. Also clean-up the whole board. I hope this will help you.
machinetosh of (tipidpc.com) site
look for kuya boy laptop
Global PC Laptop Professional Services
09126888500
Apr 01, 2010 | Toshiba Satellite 1905-S303 Notebook
My hp dv9000 will not boot. when power is turned on all leds light up screen stays black. hard drive and fan can not be heard. restarts after 10 seconds with no error message or flashing lights.
Remove the hdd cover from the bottom and make sure it is completely seated and connected. If the hdd is properly installed and it still will not boot, try entering the CMOS Setup. If you can enter setup you most likely have a bad hdd. If you can't you need to take or send the pc to a repair shop.
Oct 06, 2009 | HP Pavilion dv9000z Notebook
Dell Dimension E520 has "NO BOOT DEVICE AVAILABLE" message. Pressing F1 F2 doesn't help. What should I do?
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Sep 03, 2009 | Dell Dimension 8400 PC Desktop
Compaq Presario R3000. Push power button and lights come on then goes dead before booting. Occassionally Windows will start booting the it goes dead. Any suggestions?
Either the power supply is putting out too low voltage or the power jack is bad.Try moving the ac adapter tip around while its starting up to see if it keeps it running or shuts it off.If it makes no difference try another ac adapter that does work for sure and see if thats the problem.If neither approach works,then the HDD may be seizing or one of the ram sticks may be bad.Some sort of hardware conflict can cause shut downs.You would have to take the bootstrap approach to narrow it down to one pacific component.
Aug 02, 2009 | Compaq Presario R3000 Notebook
Error message when I openmy computer:
-Take a look in your BIOS console to see if your primary boot device is connected and shown in the list.
-if yes then, bootsector on primary boot device is missing, and you might have to connect this HDD to a different computer and back your data up, and then connect it back to your computer and run the windows recovery. make sure you scan for bad sectors after your system is up and running.
-if no, then shut your computer off and groud yourself and take all the precautions for static and open the cabinet and make sure that your primary boot disk is securely connected to the motherboard and power connector is firmly connected to it (you can try switching the cables to see if its an issue with the cables, motherboard ports or power supply)
hope this helps you to pin point the issue..
Dec 22, 2008 | Computers & Internet
Dell latitude D600 problem
The flashing caps lock is an indication of a failed POWER on Self-Test (POST)
Remove the HDD, Battery, AC adapter, RAM and Modem
Press and hold power button for 15 seconds
Connect AC, see if you get any beep codes. If you do, power off, disconnect power, insert RAM, connect AC and reboot. If system boots, power off and add hard drive. If it doesn't, replace the motherboard.
If the system boots with RAM, but fails to boot with HDD, replace HDD 1st.
Jun 25, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
57 people viewed this question
Alun Cox
David Payne
David Payne
