Question about Lakewood HV 18-c Floor / Box Fan
Engine trouble while in use, it seems that the rotor hardly turn and eventually stop
    President:
  • 632 Answers
Clean bushing and check alignment and lubrication..
Posted on Jun 22, 2009
How do i separate the engine from generator on powermate 5000
It generally has a long rotor through bolt accessibile from the generator end, this forces the generator rotor onto a tapered shaft on the engine. Once removed the through bolt slide a long bar ion the hole and screw the bolt back in, that will force it off the taper
Oct 29, 2012 | Coleman Powermate Portable Generator...
93 honda accord wont start check engine light blinks rapidly
was there a solution to this one? my 93 accord lx is having the same trouble except it wont start at all now. ive got gas and spark and will crank but not start. wont throw a trouble code either just get the flashing CEL and clicking from control box which stops when the egr purge connector is opened. does anyone know the sequece of the egr/evap system. seems like something is getting hung up there. thanks
Jul 09, 2012 | Cars & Trucks
Vibration in brakes when stoping,had rotor turned and then replace problem comes back in just a few miles less than 100 .If you brake hard it seems to help for a stop or two.
One of the calipers may need to be changed. t may not be releasing completely and causing the brakes to ride on the rotors continent which would eventually rub grooves in the rotors. Also the tire may need to be speed balanced. When the fixed the brakes it may have taken care of some type of vibration but the tire could be the real culprit.
Apr 19, 2011 | 2006 GMC Sierra 1500 2WD
2005 Chrysler town and country abs light on, but no trouble codes showing. car brakes seem to be fine.
We own a 2005 Chrysler Pacifica (3.8 litre) and currently have the same problem. This has happened at least 2 other times on our vehicle. Our trouble code was for a faulty ABS wheel sensor, and after searching the internet I found A LOT of other Pacifica owners had the same problem. The first time this happened to us, it was covered under the Chrysler warranty. The second time, it cost about $275 to repair. This is something that only a Chrysler / Dodge dealer can diagnose and repair. At first, we went to Firestone and they preceded to replace the brake pads, rotors, flushed the master cylinder and nothing they did seemed to work. Finally, I went to the Chrysler dealer and they immediately diagnosed the problem and fixed it. I am not sure if the computer will actually report a trouble code for the ABS problem or not. I will warn you that even though the brakes seem fine, eventually they WILL fail on you and you will have SIGNIFICANTLY reduced stopping power. Our light went on while we were down the interstate at 70 mph, and let me tell you that was a very scary situation with me, wife and two kids with NO CONTROL over how fast we could stop. Take your vehicle to the dealer and get fixed, it's not worth risking an accident. Good luck!
May 09, 2010 | 2005 Chrysler Town & Country
Sputtering, hard start in moisture
next time it does this, try spraying wD40 on the distributor, all around it. if this fixes it, you have a crack in the distributor cover. just replace it. good luck
Dec 01, 2008 | 2001 Volkswagen Beetle
1991 Sidekick 4 door misses terribly
check lo tension wires,, the power supply to the coil and any connections in this circuit
lcbr1911
Sep 07, 2008 | 1991 Suzuki Sidekick
Front brakes binding and grinding
Sounds like your brake calibers are sticking. Get new ones and new pads. You probably should get new rotors also because with the dragging calibers they most likely got hot and are warped. Search on ebay and www.rockauto.com . I personally use power stop drilled and slotted rotors with mid grade pads. You can probably get a whole kit.
Oct 22, 2017 | 2000 Ford Windstar
F&P Smart Drive #703 trouble
possible outer casing out of alinment, try lining up while doing up the bolts. Regards Engineer
Jul 08, 2007 | Fisher and Paykel GWL11 Top Load Washer
Lakewood HV 18-c Floor / Box Fan Logo
288 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
