Question about Dryers
Dryer will not ignite and heat on speed queen stt30 stacked dryer
  • 1028 Answers
SOURCE: Speed Queen gas dryer won't heat
probably not most likely bad coils on gas valve the 2 black dohickys with wires
Posted on Jul 23, 2008
tzweeb
  • 318 Answers
SOURCE: Speed Queen dryer does not heat...
you have weak gas valkve coils and they will work when cold but after a few cycles they become electrically open and will not allow the gas to flow.
just replace both gas valve coils and that will fix your problem.
Posted on Dec 29, 2008
erpaalai
  • 999 Answers
SOURCE: coin operated speed queen gas dryer works some
Check the coils on the gas valve. Sounds like an intermittent one. Eric
Posted on Jun 20, 2009
canbruce75
  • 1776 Answers
SOURCE: LPG kit for Speed Queen 30XG gas dryer
You should be able to convert it over. Check out the link that I am providing. It's information on the conversion process and what it entails. Hope this helped and best wishes.
http://fixitnow.com/wp/2009/03/13/converting-a-gas-dryer-from-natural-gas-to-propane/
Posted on Sep 06, 2009
heatman101
  • 43501 Answers
SOURCE: Dryer does not heat. Electric ignition does not "spark" lighting
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
Speed queen gas dryer, at least 20 yrs old: the igniter begins to glow, then fades out, there doesn't seem to be gas ignition as the chlothes are not drying...so?
Sounds like you may need some coils. Mine would heat up for a minute then go out. The coils were my problem. They are located close to the igniter. They come 2 in a pack and you have to replace both. Probably $20
Oct 07, 2017 | Speed Queen Dryers
I have a speed queen gas dryer model number Aqm499w2 that will not heat up.
Better give technicians a call your problem seems the igniter is busted.
Nov 06, 2010 | Speed Queen AES68AWF Gas Dryers
My speed queen gas dryer comes on but will no longer heat. The igniter is fine.....passes the Ohm test. What might be the solution? And what are the est. part costs....this is an old speed...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It works on amps... not ohms...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Dryers
Speed Queen gas dryer model #AGM499W. Replaced the igniter but did not fix the problem. Dryer will not heat.
burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
Sep 02, 2010 | Speed Queen AGS28AWF Gas Dryer
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
My speed queen dryer model st0300 has no spark
The dryers do not spark, but light with a hot surface ignitor. This is often the cause of no heat for gad dryers...
Checkout this tip that I wrote about this problem..
heatman101
Mar 30, 2010 | Dryers
Electric maytag stack dryer not heating...
That dryer is made by Speed Queen. A common failure part is the thermal overload, mounted on the heater box. Items 4 and 6 in the picture Iposted are possiblities.
Dec 14, 2008 | Maytag SDE2606 Electric Dryer
Speed queen commerical dryer
try replacing the gas valve coils. they are cheap
Jul 25, 2008 | Speed Queen CGS68AWF Gas Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
Marvin
Marvin
