Question about GE WBVH6240F Front Load Washer
Washer on will not start
Ge front load washer is on but will not run start button beeps when pushed
  • Anonymous Nov 23, 2007
    My washer turns on, will allow me to set cycle but when I push the start button it double beeps and does nothing, normally the door will lock and washer will turn on.
I inherited one of these washers with a house I just purchased, and it had the exact same symptom. I finally discovered that the tiny little plastic door switch was broken off. This is the little switch that pushes in when you close the door, which lets the washer know the door is shut. Huge hassle trying to get it repaired under warranty, so for now I've just glued the little plastic piece back on.
Posted on Jan 03, 2008
  • 1,294 Answers
Is your inlet pipe to the machine "on"?, is the door firmly shut? Have you overloaded the machine? The inlet pipe is not clogged......
Posted on Nov 29, 2007
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
GE front load washer wont start model #WHDVH626FWW
there is a chance that your door lock has failed
Feb 06, 2010 | GE WSXH208A Front Load Washer
Can the door swing on a GE wbvh5200j3ww washer be switched?
Nov 17, 2009 | General Electric WBVH5200J Front Load...
My GE washer wbvh5300kww beeps at me when I hit start
I am also having this problem as well. Trying to seek (once again) a solution as having to plug/unplug the washer before each use is really annoying.
Can anyone tell me how to run the test mode for this washer? I don't see that detail anywhere in my manual. Thanks.
Oct 27, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Need to reset washer it is stuck in mid cycle and wont continue nor start over
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
Jul 24, 2017 | GE WBVH6240F Front Load Washer
Frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
Feb 23, 2009 | GE WSXH208A Front Load Washer
HE3 Washer just keeps beeping at me when I push the start button
Bad motor pump and it's a common problem kenmore elite front load washer so we need to left the washer from the front and get under the washer to get the motor pump replaced
Nov 05, 2008 | Kenmore Elite 45986 Front Load Washer
Front load GE washer
you just push the delay button once and the light will go off.
Oct 17, 2008 | GE WSXH208A Front Load Washer
Front load washer model #WSSH300G0WW
push the button again...... its a toggle button the delay is either on or off.
Jan 21, 2008 | GE WSXH208A Front Load Washer
GE WBVH6240F Front Load Washer Logo
182 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
