I have a coleman ac that cycles on and off , the
I have a coleman ac that cycles on and off , the first time i start it up it runs about 4 minutes then compressor shuts down then it tries to restart but doesn't stay on but half minute. And it does blow cold air during the first initial start up.
  • Ned C Cook
    Ned C Cook May 11, 2010
    Is it conflicting with any pre program?
  • 38 Answers
Your system is shutting off on low pressure, you need to get it looked at to find a refrigerant leak
Posted on Jul 01, 2009
2007 dodge nitro AC will only work after engine heats up
clutch problem in the ac compressor pulley have it checked
May 22, 2014 | Dodge Nitro Cars & Trucks
Coleman mach ac blower stopped
bad motor windings.replace the motor
May 07, 2012 | Coleman Mach III Air Conditioner
Model coleman mach 8333c8714 serie 8000 my a/c start for 2-3 minutes and than the a/c shut down but the fan still working!! after a few minutes , it want to start again but dont seem to be able to. you can...
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jun 15, 2010 | Coleman Mach III Air Conditioner
It runs cold briefly for about 4 to 5 minutes then
Check the compressor capacitor. It would have gone weak. Replace with the identical value and type.
May 26, 2010 | Coleman Mach III Air Conditioner
I have a pro th4000 series honeywell programmable thermostat and its for system type th4110d electric heat with ac how do i set the thermostat to drop a few degrees before the heat turns on right now i got...
this thermostat does not have a deadband option, the only other thing you can do is set the program for a different temp. the cycles per hour just restrict how many times the unit comes on.
Dec 15, 2009 | Coleman Heating & Cooling
Ac fedders portable
Im not sure I understand the problem. Your AC runs about 4 minutes then the compressor stops and the fan stops as well? What is the model of the air conditioner?
Jun 29, 2009 | Coleman Mach III Air Conditioner
Compressor on my RV coleman ac unit bogging down
Take a look at your start capacitor. This the capacitor that kicks the compressor over when it tries to start. If the capacitor is bad, it cannot kick the compressor back over after the first cycle because the head pressure has not evened out yet. It is located in the upper unit on the side panel in a small box. Be careful, highly charged capacitors can zap you if you are not careful. Disconnect power and touch across the terminals with a meter or a screwdriver to discharge the capacitor.
Hope this helps,
Jeff
Jun 29, 2009 | Coleman Mach 15 Air Conditioner
Coleman PM0433500 Brushless Generator will not make power
Bad capacitor. They cost 13 bucks. Call 800-445-1805 to buy one.
May 31, 2009 | Coleman Powermate Powermate 5000W...
Coleman ac problem
could be bad start capacitor for compressor, cheap fix, anything else could be internal in system or compressor
Apr 10, 2009 | Heating & Cooling
Coleman mach 8333 kicks breaker
I changed out the startup and run capacitors. A/C runs fine now
Jul 22, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
100 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
