Question about Garmin Nuvi 760 Car GPS Receiver
Turned the Nuvi 750 off while searching for a POI and now it will not turn back on.
  • 385 Answers
Slide the power key to the left for 8 seconds plus, to reset it
or 30 seconds plus, to try calibrate the screen.
Regards.
Posted on Jun 22, 2009
Garmin nuvi 50lm only shows garmin screen and just a bit of green on the bottom. sometimes it shows the green register bar all the way accross
Garmin nuvi 50LM Boot problem ' POI Factory
www.poi-factory.com > Garmin talk
Aug 11, 2012 - Why won't my nuvi 30, 40, or 50 go past the Garmin logo screen when I turn it on? .... Just wanted to say thanks to Muell9K for the hard reset solution. ... get the Nuvi to start up with the screen that shows the picture of a Garmin ...
Crap... White Screen (nuvi 350)
May 11, 2008
garmin frozen?? (how do I reset?)
May 11, 2008
More results from www.poi-factory.com
How to Reset the Garmin nuvi 30, 40 and 50 with GPS City ...
? 0:51
https://www.youtube.com/watch?v=mujdSP-fM98
Jul 31, 2012 - Uploaded by GPSCity
In this video learn how to RESET the Garmin nuvi 30, 40, and 50GPS back to factory default settings. Back up all ... With the GPS unit off, press the bottom right hand corner of the screen. Turn the unit ... Show more. Show less.
Jan 05, 2016 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
When i power it on on battery power it opens showing the Garmin sign and after 5 seconds flashes off and them back on and keeps cycling. When I plug it into DC power and my computer it will power up and...
A file might have corrupted on the system.
If you uploaded some POI file just before the crash, it might be a defective POI database. You can delete it by booting in test mode (turn device off, press on the lower left corner, keeping pressed turn the device on, wait for the test menu to appear. If the unit stays on, you can connect it to a computer and see its memory, locating the poi.gpi file in the POI folder. Move it on your computer (just to have a backup; one never knows), safely remove and disconnect the USB device from the PC and power cycle the Nuvi).
Assuming it's not the POI, you will have to perform the Firmware Restore on your device (or you might install the newest firmware from Garmin, as well). When in Test Mode (see above), the Garmin Web Updater function should work: http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Also, you may try a Master Reset:
http://www.gpsdiscussion.com/garmin-gps/2183-your-nuvi-having-trouble-picking-up-signal-acting-lethargic-do-master-reset.htm
Nov 10, 2010 | Garmin nuvi 260W GPS Receiver
My GPS keeps reseting itself! I turn it on, the Garmin sign shows up and it dies! and then I turn it on again and it dies again! So, I cannot use my GPS at all! It was working just fine and its been couple...
http://www.gpsdiscussion.com/garmin-gps/2183-your-nuvi-having-trouble-picking-up-signal-acting-lethargic-do-master-reset.html
Sep 01, 2010 | Garmin nuvi 260W GPS Receiver
My wife entered the wrong pin number by accident on the nuvi 750. She tried turning the unit off and then back on to reset back to "enter pin" code mode however she gets the response "you must return to...
If you turn the unit off, wait about ten seconds and turn it back on, yes, it should go back to the "Enter PIN" screen. If, however, you turn it off then immediately turn it back on it will continue to tell you to return to the security location.
Jul 07, 2010 | Garmin nuvi 750 GPS Receiver
1 year old nuvi 750 was working fine, blinked off and it cannot be turned back on by any means
there are no owner servicable parts on the unit your GPS is defective, it takes special tools to open it up even to check the battery. contact Garmin service at www.mygarmin.com
May 12, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
My 765 cut off and will not turn back on.
Garmin has a major software bug with all of the 7X5 units. My unit just got back from service. If it will not power up you will have to contact Garmin for a RMA number and send it back to them.
Jun 27, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Sound is gone on Nuvi 750. Have reset all and turned on and off. Still no sound.. No voice no nothing Help
undo the case with the two screws and disconnect the main battey and the back up battey and put it back together. this fixed the problem with audio and not turning on.
Feb 28, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
GARMIN 260W
Hi It is more important to know how to add POIs. Here is a simple tip:
1. Create some directory especially for download. I use the following one: C:\Garmin_POI_GPS_DATA_TEAM
2. Download and save all CSV and BMP files to that directory. You may create any subdirectory and use it to save POIs for that category.
I use: C:\Garmin_POI_GPS_DATA_TEAM\Restaurants, C:\Garmin_POI_GPS_DATA_TEAM\Petrol etc.
3. Garmin's POI Loader will find all files in these subfolders and will use them to create a category.
Garmin POI Loader will search through the directory C:\Garmin_POI_GPS_DATA_TEAM and will create/transfer all corresponding POIs to your connected GPS.
4. You can remove any POI file simply by removing it from your POI folder. and re-running the POI Loader software. This POI update procedure takes about 1-2 minutes.
In summary, keep your POI files updated on your PC and run POI Loader to update your GPS or SD card via any SD card reader.
Cheers
Feb 13, 2009 | Garmin nuvi 260W GPS Receiver
Used Garmin 750 once without problem... then prob with POI menu
TOOK IT BACK TO SAM'S CLUB AND GOT ANOTHER NEW ONE......... THANKS
Dec 27, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Nuvi 360 Stuck on loading maps
Have you reset the unit yet (little pusbutton behind the aerial)
Jul 30, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 760  Car GPS Receiver Logo
76 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
