Question about Cuisinart Brew Central DCC-1200W, 12-Cup 12-Cup Coffee Maker
Cuisinart 12 cup coffe maker - dc-1200
N this be repaired?
I have tried decalcifying it already. The problem started all of a sudden, nlot gradually building up over time.
  • 85 Answers
Re: cuisinart 12 cup coffe maker - dc-1200
Hello sudyealf,
This is a common problem with this unit.
I recently had this similar problem. If you still have your machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used an eyeglass screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 09, 2009
    Problem Solver:
  • 17 Answers
Yes ,this unit is repairable.However,you might try using a product called CLR (decalcifier).Available at most all stores.Use about 4cups.Run through unit about three times.Then run 4 or 5 full carafes of water through.If the unit is working correctly, and the ball valve inside the intake hose is ok, it should work fine.If not,then it would seem to be a thermostat problem located on the heating element. I would contact a small appliance service center in your area.Repair cost will vary.
Posted on Nov 07, 2007
0 characters
3 Points
I put in 12 cups of water but only get 4 cups of coffee. what is wrong
Are you sure 8 cups of water is a lot to LOOSE it has to be somewhere i am used to loosing 1/2 cup in the grounds if i make 8 or more cups i have 2 of these coffe makers one in each house the only times i ever loose more is when the filter isnt properly seated and it flows around it and makes a major mess get your coffee maker into a good light and pour water into the filter(coffee maker off) with the carafe out fill it about 1/2 way no water should leak thru then slip the carafe into place the filter should empty if the water flowed when the carafe was out your filter basket and holder arent seated or the valve on the bottom of the holder is clogged and/or held open
Dec 26, 2010 | Cuisinart DCC-1200 Coffee Maker
Unit will not always turn on.
Sounds like you have a short. Call cuisinart. They are very helpful. They have a 3 year warranty, if yours is under three years old they will replace it for shipping costs. Their number is 1-800-726-0190.
Jun 30, 2010 | Cuisinart DCC-1200 Coffee Maker
Need instruction booklet for DCC-1200BWFR Cuisinart coffe maker?
The manual is available here:
The FR just indicates "Factory Repair" - which means it is a Refurbished item - did you buy it online, Overstock, or Big Lots?
Jul 16, 2009 | Cuisinart 12-Cup Programmable Coffeemaker...
It takes about 30 minutes or longer to brew 6 cups of coffee, i have cleaned it with vinager many times does not help it brew quicker
Hello jkdpip,
There are two possible issues, but easy to do. When decalcifying your unit the solution should be 2 parts water and 1 part vinegar. So if you have a 12 cup maker it would be 8 cups water and 4 cups vinegar. Complete the process with a pot or two of fresh water to rinse. Second, there may be a water filter stick that is removable. Open the lid and look for it in one of the corners, pull it out and remove the carbon filter there. (You can get a new on Amazon). Then replace the stick.
I hope this is a help for you. If it is please leave positive feedback for me. Thanks! NormanZ
Jul 13, 2009 | Cuisinart DCC-1200 Coffee Maker
Can one buy Cuisinart dcc 1200 coffee maker heater elements
Hello handkrobbins,
Yes, you can buy the heater elements but not from Cuisinart directly. You will need to find a small appliance repair shop to order it for you. I hope this was helpful to you. Positive feedback is appreciated. Good luck and regards, NormanZ
Jul 01, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart coffe maker self clean
I found the manual here
Oct 28, 2008 | Cuisinart DCC-1200 Coffee Maker
you said you clean it you use vinegar or decalcifier vinegar remove calcium in piece it might block the orifise if you use decalcifier it melt the calcium 1part solution to 1 part water dont forget to rinse very good that stuff is nasty cheers
Jan 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart Brew Central  DCC-1200W, 12-Cup 12-Cup Coffee Maker Logo
943 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Richard Roth
Richard Roth
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
