Question about Garden
Problem replacing belt on a ols rear engine snapper?
I bought a new belt and installed it. Belt is to tight blades engage as soon as mower is started. I have old belt same size but ripped in half. Can not seem to find any adjustment for new belt
  • same463 May 11, 2010
    Possible that the belt has been installed inproperly. Is it the normal Snapper belt that is six sided?
  • 513 Answers
What kind of mower & model # i may be able to help thanks wade
Posted on Jul 04, 2009
Blades won't engage. I hit something, blades quit turning, check belt, its okay. When you hit button to engage blades, you hear click
When you look under the mower do you see two belts ? Top one goes to the rear axle and lower one goes to mower deck spindle.
Your description sounds like the electric clutch is engaging,so if you are seeing two belts coming off the bottom of the engine maybe the belt bounced off a idler pulley on the deck and is not tight enough.
Apr 09, 2016 | Garden
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
Snapper 23 series mower blade will not engage
sounds like you belt is disengaged or just wore out, these type belts look good just to look at them, but they can stretch and get rounded a little bit of can mean a lot
Apr 05, 2014 | Snapper Garden
Mower blade not engaging
Check your belt. May broke, off, slipping.
Snapper mower
If the hand brake is on that will also kill the engine.
Oct 30, 2017 | Snapper Garden
I engage the mower blades, put the tractor in drive and the blades stop
sounds like the safety switch is out of adjustment
Apr 06, 2012 | Garden
The belt that drives the blades for cutting has broken and I need to replace it. I have a Craftsman LTX1000 lawn tractor and I've misplaced the manual. The belt is 96" long. Not sure where to...
With the mower off.
Look on top of the deck.Find the pulleys for the blades then find the engine pulley.There should be one more pulley that is the tension pulley.Watch that pulley as you pull the engage blade lever,while still turned off.The belt will go on the blade pulleys,and the engine pulley,it needs the tension pulley to push it tight.So you need to make sure it goes on the inside of the tension pulley.If you get the belt on and it does not engage,just remove it and replace it on the opposite side of the tension pulley.
May 12, 2011 | Craftsman 42 in. Precision Cut Plus 24hp...
Snapper Zero Turn mower. Blade will not engage. Any suggestions?
I am not sure what type of blade engagement mechanism you have (ex. clutch, tensioner/idler pulley, etc...) but make sure that the blades can spin freely with the belt taken off of their pulleys. It could very well be that one of the pulley bearings is seized.
May 06, 2010 | Garden
VIBRATION-THRU SEAT & FOOT RESTS AFTER ENGAGING BLADE
get down and gun your fingers in the slot that the belt rides in, soulds like you may have a small rock or piece of wood lodged in the v part of one of the pulleys. I bet thats it Jim
Dec 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
363 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
