Question about Panasonic PT-51HX43 51" Rear Projection Television
I have a panasonic rear projection 53" TV model PT-51hx43G. Just got this bad boy back from my ex wife and when i turn it on the power led flashes 3/5 times and goes dim. I have checked the power and control pcb's for cold solder joints etc reseated and cleaned all connectors with alcohol and contact cleaner etc. HELP!!!!
  • 1 more comment
  • Derek Jun 23, 2009
    The LED blinks 5 times I have verified this three times and each time it blinks 5 times only.
    Thanks for the assist
  • Derek Jun 28, 2009
    Slinteriors, would you be able to email me or make contact regarding the issue with my 53" panasonic tv.
    it is throwing 5 led flashes each time
  • Derek Jul 06, 2009
    would the problem be that the IC has failed? and is there anything else within the circuit that may have also failed?
    where would be the best place to buy the IC required to replace the faulty one and would you have the part #
    Thanks
    Derek
  • Panasonic Master
  • 8,617 Answers
Count the led blink as thats an error code. If it blinks three times its indicating the convergence Circuit has failed. Let me know the actual blink number and I will assist you.
Posted on Jun 22, 2009
  • Sonny Berry
    Sonny Berry Jun 28, 2009
    5 blinks means there is a problem with IC4511 on the DG board.
Power would not stay on red led flashes
I do not think we will get a response from person asking but you are correct, number of blinks indicates where problem is, the two most common are either a sequence of 3 blinks or one of 5 blinks.
Hard to help unless blink count is known.
SD TECH
Oct 23, 2011 | Panasonic PT-53WX42 53" Rear Projection...
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-56WX33/red light blinks 3 times ovr-n-ovr
It's one of two things, a bad chipset, or bad lamp. 200-250 repair. Hope this helps
Jul 07, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Projection HDTV won't power up, red LED flashes in front
i am having same problem. 3 flashes indicate convergence problem according to auto diagnostics that you are seeing(info from service manual).
i am starting by replacing stk392-110 convergence amp ic($6 at electronic.com). just ordered them, will let you know how it goes. please check this site-- http://biobug.org/ht/panasonic/ -- very good step-by-step on procedure.
will need service manual afterward. email me if you want copy.
good luck and godspeed,
bridgeman001
Apr 17, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic projection hdtv
My panasonic projection tv's converge does not get fixed. does any one has solution.
Jul 15, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-51HX43G no power, red light flashes
I have a Panasonic PT53TW53G projection tv that had the same problem for power .A terrific person gave us wonderful advice and it fixed our tv! We were told to replace the IC conversion amplifiers. On our model they are STK392-110 (your's may be different). We ordered the parts from www.electronix.com and they were only $12. for the two parts. We also had to purchase a soldering iron and de-soldering vac for removal/replacement of parts. Good Luck!
Feb 04, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Powers down after start up
over load on the power supply/poss. power/convergence or shorted video ic on the crt neck board.
Oct 03, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Power button flashing red
stk convergence packs may haqve failed in the dead short mode stk392-110 removing them from circuit may allow the set to turn on again good possibility do you know how to solder?
Dec 07, 2006 | Panasonic PT-53X54 53" Rear Projection...
Panasonic PT-51HX43 51" Rear Projection Television Logo
305 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
