Question about HTC G1
Bluetooth headset problem
I pared Motorola S805 bluetooth headset to my G1 phone. The problem is that music played on this phone I can hear only thru the dialing. Weird?
  • rimmash Jun 22, 2009
    Thank you for your answer, but this phone have only one option for bluetooth connection.
    President:
  • 2,923 Answers
There are two types of profiles that Bluetooth headsets uses. One, it is called the A2DP (Advanced Digital Profile) and second is called the Headset profile (Mono).
The A2DP is used for listening music that's transmitted from the phone to the headset.
The Headset profile is used for calling. But the A2DP can also be used for calling if the phone or the headset support it.
If one of your device (either the phone or the headset) doesn't support it, then that could be the reason why you couldn't hear the sound.
If both devices support A2DP, make sure that your headset is connected to the phone via the A2DP profile.
You need to refer to the phone manual to see if it's supported by your phone and how to connect to it.
Hope I explained it properly. Have a great day!
Posted on Jun 22, 2009
I have a droid x and i cant listen to voice messages or music thru my blue tooth... any suggestions.
Check your bluetooth and make sure that it is capable of playing music through the headset. I had a Motorola Bluetooth headset that was unable to play music through it, but I later then upgraded to a Plantronics headset, and this played music just fine.
http://www.plantronics.com/us/product/voyager-pro
As for not being able to hear voice messages through your bluetooth headset, make sure that the volumes are up on both the device and the headset, and try deleting the paired device and re-pairing it!
Feb 25, 2011 | Motorola Mobility Droid X
Want to use blue tooth to listen to music on my g1 instead of ear buds
U can connect your mobile to bluetooth headset. In bluetooth option there with be "Search for audio enhancement" option it will find out if your bluetooth headset is on and working. If u connect you can hear thru bluetooth. Pls vote for me if my suggestion is helpful.
Regards, Kesav
Mar 03, 2010 | HTC G1 Smartphone
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Nov 13, 2009 | Motorola Mobility S805 Wireless Headset
Can't connect a motorola hs850 with a samsung m520.
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Jun 23, 2009 | HTC G1 Smartphone
Music trouble
Not all bluetooth headsets can play music. If you hear music on your headset when you close your phone then your bluetooth is set for it. If not, you are unable to use that bluetooth for music.
Mar 18, 2009 | Motorola Mobility H550 - Bluetooth Headset...
Pairing Nokia N78 with Motorola S805
pair using the wired headset first and that will sort
Jan 09, 2009 | Motorola Mobility S805 Wireless Headset
No audio from computer to Motorola S805 Headset
I posted this problem a long time ago. I updated to Windows 7 and my headphones immediately worked flawlessly!!
Dec 29, 2008 | Motorola Mobility S805 Wireless Headset
Motorola stereo bluethooth headphones
The G1 Doesnt support Bluetooth A2DP yet, meaning it cant stream music via Bluetooth. Yet !
Oct 27, 2008 | HTC G1
Music not playing through bluetooth
it plays through the main spkr only nt frm th ear part
Dec 30, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Bluetooth Stereo headphones
according to the specs ive read these are the bluetooth profiles supported by your phone :
Bluetooth® Supported Profiles: dial-up networking, headset, hands-free, file transfer, imaging, printing, JSR-82
copied directly from motorola website........so in other words your phone does not support the bluetooth stereo profile.....so the headset may function as an earpiece but music play wont be possible
Dec 13, 2007 | Motorola Mobility SLVR L7 Cellular Phone
HTC G1 Logo
366 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
