Question about Gateway 831GM PC Desktop
Hi, I have a Gateway831GM. When I try starting it, it beeps three times with the fan running at a high rate. Nothing else happens...nothing on the monitor. I've tried several times to turn it off and back on and no luck, same thing happens. Any ideas? And would it be worth taking in for repair? Thank you.
    Scholar:
  • 109 Answers
Its a RAM problem if its three short beeps. Take the left panel of the case off and access the RAM modules. Push them down and make sure they are snapped into place with the plastic tabs on each side of the slots.
If its one long beep and two short beeps its a video card error..do the same thing you would do if it was the RAM modules.
Posted on Jun 22, 2009
  • Kevin Currence
    Kevin Currence Apr 10, 2011
    what if there is no beep when i hit the power the fan inside runs realy fast not the 1 on the power supply the 1 inside and there is no beeps at all
  • 58 Answers
Hi, those beeps mean something is wrong, perhaps one of the cards inside the box have come out of their slot partially? If you feel able, unplug the power and make sure all of the cards and memory chips are firmly seated, then try again
LTF2140ES0 washer just beeps three times, wont start
Frigidaire engineers are so smart they programmed it to beep 3 times for door lock problem, draining problem and other problems in the internal electronics and didn't bother to give the users specific info to read off the machine.
Oct 30, 2008 | Frigidaire 14 Cycle Tumble Action Washer
When i press the on button, the fan comes on and three beeps that follow and nothing else happens.
three beeps indicates a ram (random access memory) problem remove on at a time ensureing the computer is switched off and power cable removed leave it for 10 mins before opening the comp as there could still be electricity or static inside the unit.
Oct 06, 2010 | E-Machines T5088 PC Desktop
I was using the computer for a short time, just reading news on the internet when it beeped three times and the monitor went blank and the mouse and keyboard also stopped working. I had to do a hard...
hi your cpu fan might be loose or your RAM open pc and make sure cpu fan is secure if its loose a little tighen it or your RAM might have popped out it can get very hot around RAM and sometimes it pops out ...hope this helps be carefull...bonnell
Sep 23, 2010 | Gateway FX7026 PC Desktop
No video
change the boot sequence from the BIOS and set the first boot to the Hard disk and check.
Nov 11, 2009 | Gateway GT5220 PC Desktop
Fujitsu lifebook n5010 notebook won't reboot i let the battery run out while working. next day, turned on three loud beeps, then three loud beeps then fan runs but no display on the screen. power off,...
Okay, sounds bad.
However, take out the battery from the laptop and remove mains lead. Go and make tea! Then, drink it. Once you have complete this task.
Plug in the AC lead ONLY into the laptop and then try to power it on.
You should see lights on the Hard Disk LED or hear a beep. If you see them but nothing on the screen at all when booting then the capacitor pack has probably gone on the screen. This is not an expensive part, but you do need to know what you are doing to replace it. Think it time to give it to the workshop or ask IT bod to look at it for you.
Oct 26, 2017 | Fujitsu Siemens Lifebook N5010 Notebook
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
GE JVM240 microwave - shut door, fan runs,can't set timer or cook
The "main" relay on the control circuit board is stuck (shorted) and needs to be replaced.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
3 beeps and fan running at start up
The three beeps shows the Memory Module Test and that symbolise that the memory module is having a problem and to my knowledge when there is a problem with the memory then you have to open the casing and remove the memory module and clean the slot very well and if slot in back and the memory do the same change the to the second memory slot if it happens there again then you change the Memory module.
ok
rate this solution.
Oct 06, 2008 | Gateway GT5408 PC Desktop
A7V8X NOTHING HAPPENING,
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Nov 07, 2007 | ASUS A7V8X Motherboard
Gateway 831GM PC Desktop Logo
170 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
