Question about Sony DPP-FP30 Thermal Photo Printer
Printing only bottom half of picture.
I tried to print with my Sony DPP FP35 printer and it printed only the bottom half a picture. When I checked the cartridge, it looked like the film was a bit crinkled on one end. I have 2 boxes of 120 each and don't want to throw it all away. What do I do? Thanks
  • tjtsputnik Jun 23, 2009
    Thanks Benny, I will try and check inside of the printer. If anything, I will probably toss it out like you did. Thanks for taking the time to help.
I had the exact same issue with mine! I didn't manage to fix it, but I know exactly what the issue is. If you open the printer, you'll find a black rectangular box above where the film fits inside the printer. This black box is connected to the board above it, and is supposed to press down against the film, and then against the paper for it to print properly. There is a little bar above the rectangular box, and there should be two plastic pieces on both ends of this bar. The bar is also connected to the gears, and when the gears move the bar, the two plastic pieces coming off of the bar push the black box down. When I looked at mine, only one of the plastic pieces was doing its job; the other one was broken, and was sliding on the bar. Tried some super glue, wouldn't work. I suggest tossing it out like I did, unless it's still under warranty or you want to try fixing the plastic piece so the printer head gets pressed down all the way.
Posted on Jun 22, 2009
Why does my cannon cp-200 printer only print half the image already changed ink cassette
it is probably set to print a certine size of the photo, can you do a print preview before printing and see what that looks like, then check all your print settings.
Sep 13, 2014 | Canon Office Equipment & Supplies
Why does printer only print half of the picture
Your paper size may be samller then the size of the image you are printing. Try changing the size of the image or size of paper to match.
Aug 12, 2014 | Sony Picture Station DPP-FP90 4x6 Photo...
Why is the sony dpp-fp90 digital photo printer only printing half the picture?
Are you using a large image size, try smaller size file..Its a data processing problem. clear the memory of the printer.If persists it could be a lose data cable in the printer if the printer has had a knock
It only prints a 6x1"
Sony printers are masterpeices when it comes to digital printing as they produce wonderful quality images.
If you got a new printer and it does the same thing this indicates that the problem iis emanating from the software with which you use in editing the pictures before sending the print command. Somewhere along the line some adjustment must have been made to the software relating to the alignment of the picture on the printer. Once this adjustment is corrected your printer will print fine.
Printers are devices which prints what command was sent to them and do not have any intelligence to act or edit documents on their own accord.
Hope this solution has been helpful?
Happy new year
Jan 03, 2011 | Sony DPP-FP30 Thermal Photo Printer
Sony DPP-FP30 do not work with wista
Sony says DPP-FP30 is compatible with Vista (both 32-bit and 64-bit) and that the printer driver is included in the Microsoft Windows Vista operating system.
However red-eye reduction, Exit Print, Auto Fine Print, enlarging preview, and reducing preview are not supported.
Check this link:
http://esupport.sony.com/US/perl/news-item.pl?&news_id=129&mdl=DPPFP30#soft1
Aug 21, 2009 | Sony DPP-FP30 Thermal Photo Printer
My sony dpp-fp55 leave 2/3 of the paper white while printing
They are thinking the cartridges are dirty or the heads. I am thinking it is a setting for the printer or an actual glitch in the printing program. If you have successfully printed on this printer before, then very carefully go through the settings, looking for print margins settings specifically. This sounds simple but you might want to make sure your paper trays are adjusted correctly.
Jun 24, 2009 | Sony DPP-FP55 Thermal Photo Printer
Sony Printer DPP-fp90
You may use your memory stick option to print. I means you shall copy your pictures to a memory stick card. Insert in into the printer. And print directly without your MAC. I use Sony DPP-FP70. It works.
Nov 01, 2008 | Sony Picture Station DPP-FP70 4x6 Photo...
TROUBLE PRINTING
These are following cases for this symptom.
If the access indicator flashes in green:
The data size of the image is large and it takes longer to process it for printing. Printing will start as soon as the data processing finishes.
If the paper error indicator flashes on the LCD:
The paper is jammed. Turn off the printer and turn it on again, take out the paper tray, and then remove the jammed paper from the paper outlet. If you cannot remove the jammed paper, consult with your Sony dealer or service facility.
If no indicator is lit or flashing:
The thermal head may be overheated. Leave the printer until the head cools down and the printer resumes printing.
May 11, 2008 | Sony DPP-FP50 Thermal Photo Printer
Printing problem
you may have a faulty Thermal element, sounds like a cold spot in the middle of the print head is messing up your photo. If this is in warranty or is new get them to replace it
Aug 22, 2007 | Sony DPP-FP50 Thermal Photo Printer
Sony DPP-FP30 Thermal Photo Printer Logo
2,456 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
