Question about Noritz 6.9 Gallon Residential Direct Vent Tankless Water Heater - N
How to remove the water filter in Noritz
How to remove the water filter from the drain valve in Noritz. Drain plug came out with ease and I don't know how to remove the water filter from the water drain valve.
  • 332 Answers
It's just a cup screen,, when you take off the cap screw you pull it out claen i and put it back,, it is on the cold side only right before the unit connection
Posted on Jun 23, 2009
  • Inacio Nov 10, 2012
    When I take off the cap screw, it can see the plastic filter but it will not come out. The Noritz book says that it should be removed and cleaned but I can't find a way to budge it. Have you been able to pull it out? And yes it ison the cold water inlet.
Vulcan electric hot water heater. I want to know how to drain enough water out in order to replace the relief valve
turn off unit turn off water supply open drain at bottom let water out close drain remove valve
Aug 31, 2017 | Water Water Heaters
Where is the Drain valve?
Usually on the bottom, looks like a hose spigot , put yard hose on it and open it up!
Jul 20, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
How to replace water heater element will water cme out when you remove element does tank have to be drained
Safest method:
Shut off electricity to heater.
Shut the water valve.
Drain heater to below the level of the element, open hot water valve in house to vent heater to speed draining.
If the element is on top, you don't have to empty the heater.
Remove old element, install new element.
Leave hot water valve open somewhere in the house.
Turn water on.
Once air is removed at hot water valve, turn electric on.
Shut water valve.
Gary
Aug 13, 2011 | Reliance /State Ind. 9002450 Element For...
Drain valve leaking. Gor replacement part. Cannot get old valve off . Does the whole valve come off , unscrew or pull off? serial number is RN1296A 18392. Will the new part fit the same New...
If valve is dripping, buy garden hose cap and screw onto valve.
Whole valve unscrews counterclockwise.
If valve is plastic, expect it to break off.
If valve is brass, use cheater bar on your pipe wrench.
I don't know that serial number or part number, but drain valves are standard 3/4" pipe thread.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
Drain valve can be rusted in place and impossible to remove without draining tank and putting water heater on it's side.
Install new water heater so drain valve is accessible, and buy new water heater with brass valve instead of plastic.
Jun 15, 2011 | Rheem Water Heaters
I have a Rheem Steller natural gas hot water service. There is a continuous dribble of water from the pressure valve overflow, even when the heater is not heating. I have tried easing the valve a few...
Yes, Turn the knob on the gas valve to off. Turn off the incoming water line into the water heater. If you have a valve on the outlet turn it off too. Open the drain at the bottom of the heater to drain a little water from heater. You can then lift the lever on the temperature/pressusre relief valve to let a little air in to release the vacuum and let the tank drain. If the relief is in the side let it drain a bit longer so the water level is below the outlet. Be sure to re-install the down pipe on the relief valve on the new valve. You should drain the a few gallons of water at least once a year from your heater, and you should exercise your temperature relief valve once a year to be sure it will function. If your new valve leaks suspect your temperature control allowing the water to get too hot.
Oct 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
For a noritz N-06315 do I need an aux drain pan if it is installed above a living space
It depends on local code, no all cities/states require drain pans, but it is always a good idea if you don't want to deal with water damage.
Jul 18, 2010 | Noritz 6.3 Gallon Residential Tankless...
Noritz tank less propane water heater, no out going pressure
There's a filter on the cold water side of the unit. You'll notice a black, plastic, cylindrical component directly below the unit on the cold water line pointing to the left. If you shut of your water and unscrew that cap, there will be a filter attached to the other end.
If the filter is clean, I'd recommend calling tech support for help. You might have an error code.
Jan 08, 2010 | Noritz Liquid Propane Tankless Water...
My reliance 606 water heater drain valve is leaking..what size do I need to replace it
You are going to have to drain it anyway. So drain it and take the old one with you to get a new one. In case you don't know turn the breaker off before you drain it. If you don.t you will melt the heating elements. They get too hot out of water.
Jan 06, 2010 | Reliance & Drain Valve for Gas Water...
Noritz Tankless error code 16
The trick with these hot water heaters is to keep the filter screen clean and flush the system with CLR periodically. Code 11 is ignition error. Is your gas valve turned on?
Oct 17, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches.     Normally the drain valves are plastic with a Male hosebib attached.  Attach a  garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve.  If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level.     Replace the P/T valve  and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads.    You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
Jan 31, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Noritz 6.9 Gallon Residential Direct Vent Tankless Water Heater - N Logo
887 people viewed this question
Top Noritz Water Heaters Experts
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
