Question about Apple iPod nano MP3 Player
My ipod nano chromatic screen is frozen, and it says it's locked, but the lock switch is off, and it's been frozen for over 6 hours on 20% battery. What's going on???
I just let the ipod sit over night, and the next morning the battery was gone. So, i could plug it back in an it charged up-- it's fine now.
Posted on Jun 22, 2009
Nano ipod will not charge and battery is low and on lock and wont disengage! help please.thanks
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
To reset an iPod with a Click Wheel: . Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Jul 11, 2010 | Audio Players & Recorders
I plugged in my i pod and came back a hour later and the screen was black and was frozen and none of the buttons would work
you will need to reset your ipod this will not delete songs. 1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Oct 21, 2009 | Apple iPod nano MP3 Player
Frozen and still locked, even though i took the lock off
please try to reformat your IPOD Nano to updated Itunes programs, i have the same like your IPOD and that what I do... and after it reformat do not remove your IPOD, shut down your Computer and then plug-out it out.
Jun 22, 2009 | Apple iPod nano MP3 Player
Frozen and locked frozen
Flip the off and on button 3 times then hold the menu button and it will restart and it should be fine
Jun 21, 2009 | Apple iPod nano MP3 Player
My ipod chromatic is completly frozen.
You are doing the reset wrong. Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Apr 07, 2009 | Apple iPod nano MP3 Player
Frozen ipod nano chromatic
here i know how to do it!
u have to press menu and the center button at the same time and keep pressing and wait
Feb 23, 2009 | Apple iPod nano 4th Generation
How do i turn my nano chromatic off
hi,
just like any other iPods, press & hold on the pause button & wait 'til the screen turns off. Just make sure you don't have it on "lock." It's the orange switch.
if you're still having difficulties, try and check your manual that comes with your iPod.
P.S don't forget to rate our answers..
thanks,
Feb 18, 2009 | Apple iPod nano MP3 Player
My i-pod nano chromatic 8 GB is stuck!:S
Press and hold the Menu and Centre buttons at the same time until the apple logo appears. (This usually takes between 5 and 10 seconds.)
Information from: http://ipodsurgery.com/reset-frozen-ipod
Feb 01, 2009 | Apple iPod nano MP3 Player
Frozen screen
First, make sure the lock slider is in the proper position.  I know, obvious, but you'd be surprised how often this happens.
Next, slide the lock slider to locked and then back.  Then press and hold the Menu and Select (center) button for 6-8 seconds.  Try a couple times if it doesn't work the first time.  The ipod should reset and work.
If that didn't work, you can reset your ipod.  But first, try connecting the ipod to your computer and see if it goes into sync mode. If so, wait for iTunes to load and then eject your ipod in iTunes and see if it works again.
To reset your ipod, slide the lock slider to locked and then back.  Next hold the Play/Pause Button and the Menu button for 6-8 seconds.  You may have to try this a couple times.  The ipod should reset.
The last thing to do is to let your ipod discharge completely by leaving it at the frozen screen.  Once your ipod is out of battery, reconnect it to you computer or a power adapter and let it charge.  Then try to access it again or repeat the steps above.
Nick
Jan 22, 2009 | Apple iPod nano
Unlock my ipod, please!
hold down the center button and the play button, see if it resets.
Otherwise, wait till the battery drains. Then the problem will be fixed
Aug 13, 2008 | Apple iPod nano
Apple iPod nano MP3 Player Logo
369 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
