Question about Olympus Camedia C-4000 Zoom Digital Camera
Lens won't move - Olympus Camedia C-4000 Zoom Digital Camera
I have a new Nikon 3100. The problem now is my 18-55 zoom lens is locked and it won't move. In the manual setting and by unclicking the outer lens auto button, the focus front lens is fine. It'
Simple answer; NO! What ever you do; do not try to force anything to move and don't try to disassemble the lens. Contact a Nikon Repair Depot (found in your instruction manual or on the Nikon USA website) and they will give you instructions for returning it for a repair estimate. If it is still in warranty, there should be no charge.
Dec 31, 2012 | Nikon D3000 D3100 18-55mm
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
Nikkor 55-200 stuck
You could take it apart, but would you be able to put it back together? Do you have a lens collimator and other gear needed to ensure proper alignment? If you don't have the proper tools, leave the job to a trained professional (or replace the lens).
Nov 18, 2011 | Cameras
I have a Canon EOS 550D camera fitted with a Canon Zoom Lens EF-S 18-200mm lens. I bought both together sometime early in 2010 from London Camera Exchange, Nottingham. I am not in Nottingham at the moment,...
Just a thought - are your Image Stabilizer and Auto Focus switches On or Off?
Might be worth experimenting with them.
Otherwise, sorry, can't help.
May be necessary to contact your vendor.
Aug 09, 2011 | Canon EFS 18200mm f3556 IS Zoom Lens + UV...
Lens will not extend when turned on message on screen lens error
This error indicate that focusing ring got stuck or jammed due sand, dust or may be due to external shock caused by dropping the device.
  • Try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Fuji Cameras
LENS OPENING BUT NOT SHUTTING
Its seems lens got stuck in the barrel due to external shock caused, Try out following steps-
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once's or twice then it will stuck again.
Else contact Olympus, your camera need to be disassembled to get at the focusing ring at Service Center .
I hope this will solve your problem
Thanks..!!
Jul 04, 2011 | Olympus Mju 725 SW Digital Camera
I have a D5000 camera w/ kit lens VR 55-200, less than a year old. Recently and only occasionally what is happening is when I press the shutter release button, the lens won't focus, it won't move...
Your camera is still under the one year Nikon warranty. Call Nikon's repair depot at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday. They will verify your warranty and assist you in returning it for repair.
Jun 08, 2011 | Nikon D5000 Digital Camera
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
Dropped the lens, the focus ring won`t move
You can send it to the canon-service but i think it will be cheaper if you buy a new or used one.
Jul 20, 2009 | Canon EF 50mm f/1.8 II Lens
Olympus Camedia C-4000 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
