FixYa.com
Tags:
Brother Multi-Function Center  MFC-440CN All-In-One InkJet Printer
Error message 50 (by 13 users)
posted by Jan2 on Nov 03, 2007
I was wondering if you could send a copy of that diagram to fix an error message 50 on the Brother MFC-240C
Thanks!
I have a MFC-440CN with an Error 50. How do I fix it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
12 Other Users Have The Same Problem
Comment by Guest, posted on Sep 06, 2008
Print error 50
Comment by kada3, posted on Jun 19, 2008
I also had a paper jam and now am getting the unable to print error 30 and 50 message. could you explain waht you meant by
put a 1,5inch tape onto the printhead cover where the encoder strip runs thru to prevent this error in future!
kada
Comment by Guest, posted on Feb 25, 2008
Had a jam, Cleared it, and now getting message "Unable to print 30 or unable to print 50"
Comment by Guest, posted on Feb 14, 2008
what error 50 on Brother 440CN
Comment by Guest, posted on Feb 08, 2008
Cannot send and receive fax messages
Best Solution
posted on Nov 04, 2007
Helpful (85)
Mix-it-up
Rank:Guru Guru
Rating: 88%, 1024 votes
have a look here:
http://www.fixya.com/support/t211210-brother_mfc845cw
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 04, 2008
Not Rated (0)
melodicminor
Rank:Apprentice Apprentice
Rating: 85%, 2 votes
Confirm Success on a 440CN
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees
2) make a note of where each connector goes
3) release the Ribbon and 3 Multicore cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees.
4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.
5) Remove front panel by disconnecting ribbon and wireing on both sides.
6) Remove 6 Screws (2 on back, three at front and one middle right
7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.
8) Re-Seat Encoder Strip into guide. (The Transparent strip)
9) Re-assemble in reverse and Hey Presto.
All Cured. Hopefully!
Can you Help with these Printers problems?
Brother Multi-Function Center MFC-440CN...
Printer ERROR "Unable to...
My BROTHER MFC-440CN printer... Answer This...
weight of MFC-440CN-A1-004
I need the weight of... Answer This...
ink cartridges
My machine will not use the... Answer This...
cant find program on computer
cant find program on computer... Answer This...
installing mfc printer.
have cord..one in inside... Answer This...
12 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Feb 03, 2008
have error msg unable to change 50 can someone please tell me how to fix it thanks
Comment by linaka, posted on Jan 07, 2008
I have a MFC-440CN with an error message 50. It won't run at all. How do I fix it?
Comment by nebelwurfer, posted on Jan 06, 2008
Is there anybody that has the MFC 440 service manual or can the Guru blow up the image of diassembly of the printer so we can read it and take it apart? it is impossible to read that picture.
Comment by Guest, posted on Jan 04, 2008
i just bought this printer and after 3-4 days it shows the same problem error 50.
this printer is really sucks.
Comment by khianrob1, posted on Jan 02, 2008
print unable 51 error. refers to troubleshooting and routine maintain section in users guide. what do I do for this?
Comment by Guest, posted on Dec 29, 2007
I have the Brother MFC-440CN printer. I had a paper jam and am now getting the error message unable to print 30 and unable to print 50. I have lost my manual and am having no luck fixing this. Please help! Thanks
I have the MFC-440CN model and had a paper jam. Now I am getting the error messages unable to print 30 and unable to print 50. I cannot find my manual and am not having any luck fixing this. Please help! Thanks
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
