Question about Microwave Ovens
For some reason the water pressure will not keep the handle from falling down and the water shutting off
  • franc486 Jun 22, 2009
    wish I could but I don't have it.... It's a single handle unit but I don't have the serial or model number. It's about 6 months old and was installed by our contractor. The problem started a few months later
    President:
  • 1,197 Answers
Kindly provide us the unit name and the model number.... it will help us narrow ur solutions....
Posted on Jun 22, 2009
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Nov 01, 2013 | KitchenAid Microwave Ovens
Microwave door alignment
test all this steps and fix it. God bless you
Oct 27, 2013 | Microwave Ovens
H5460NO/01 door lock is not working
test this steps and fix it. God bless you
The door doesn't open
please follow the instruction and fix it. God bless you
May 28, 2013 | Cuisinart Microwave Ovens
We have semi-successfully replaced our Moen cartridge for model 100940. We have no more leaks, the only problem is that the water will not stay on. When we lift the handle up, it immediately starts to...
I know this is an old question, but I just had this issue when replacing the cartridge in my 100940 J1 Moen faucet. I had to tighten the Phillips-head screw down a little more that holds the plastic piece on to the cartridge stem. Hope that's the fix you needed.
Apr 01, 2011 | Microwave Ovens
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
LG LMV1650ST handle falling off and needs to be replaced
The lower door handle bracket broke and I'm trying to find out how to replace it. I already have the new bracket.
Jun 23, 2009 | LG LMV1650ST Microwave Oven
Microwave not heating
You need to replace the whole door latch with an original part.
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Mar 18, 2009 | GE Advantium SCA1001SS Convection /...
Handle screw broken
You have to take the trim off the in side of the door around the glass. Be careful, because the glass could fall out. You should be able to open it with a regular flathead screw driver. There is probably 4 screws holding the handle on. I am pretty sure the only way to get the part is through whirlpool.
Jan 26, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
