Question about Carrier Heating & Cooling
Carrier infinity system, sensor error
Everytime it rains my ac system goes down. On the infinity control the display shows sens error where the outside temp would normally display. I also get a generic system malfunction error (call Carrier) on the display. If I heat up the outside air thermistor with a hair dryer, the outside temp eventually comes back on the display and the system usually starts back up. I have an FE4A air handler, infinity control and 2,5 ton 15 seer compressor. How can I get trouble shoot guide in order to interogate error codes? I also observed system com error (16) flashing on the led on the control board. Is that error related to the sens error ?
SOURCE: I need to know the seer number for an air handler. I'd
On the air handler take the top panel off, look to the left on the inside, this will give you general information on the unit on a stampede plate. This will
give you the date of manufactuer as well.
On the outdoor unit, there is a stamped plate on the
condensing unit. Should have year of manufactuer, it
should also say how many pounds of freon should be
in it. The Model number is what you need to know
to find out how big it is.
024=24,000 BTU= 2ton unit
030=30,000 BTU=2 1/2ton
036=36,000 BTU=3ton
040=40,000BTU= 3 1/2ton
and so on.
My guess is that it is an older unit and since I have
been installling units since 1995 I have only known
any older units to be at least a 10 SEER and no more.
Posted on Feb 17, 2010
SOURCE: I have a carrier infinity
A burned or pitted contactor will/can cause a unit to not run. Outside fan. Just thinking out loud. Start with low voltage check at t.stat then check outside low volt. Set t.stat to on. If fan engages at least your transformer is good. Next set calling for cool. Drop t.stat 68-70. If nothing happens go outside and with a screwdriver depress the contactor in. If fan and compressor kicks in change the contactor. If contactor is pulled in check outside fan. Remove the wires from the compressor and see if the fan will run . If it does you have eliminated start components as good. The compressor has to be check. It needs to be ohmed out. Turn off power at disconnect. Pull the cover on the compressor. Check between pins; then pins to ground. Open or infinite is good.Have you checked fuses. Like small 3-5 amp fuses
Posted on Jul 03, 2008
  • 3 Answers
SOURCE: Carrier air handler tonnage?
That is a fairly large difference. It is usually ok to have the inside evap. coil and blower up to 1 ton larger than the outside condenser. That will make the unit slightly more efficient as well as less likely to freeze up on low airflow situations. It is not recommended to install a new condenser on an old evap coil. There has been a lot of changes to the design of the coils in the last little while. For example a 10 year old 2 ton coil may only have 3 cubic feet of volume but a new 2 ton coil may have 4 cubit feet of volume.
There are many factors that may have infulenced the decision on what size condenser to install. Many of which can only be done by visiting the home and doing alot of work, checking the duct sizing bioth supply and return, inspecting the insulation and windows of the home etc. etc. Most of the time that never gets done. You can blame the contractor for not doing a complete check, but at the same time you can blame the customer because many contractors that are that good loose the job to a cheaper bid that did not no any of the research. It is a catch 22 for everyone involved.
There is ALOT more to sizing equipment that many people think, sadly that also includes many HVAC contractors. Way too many people use "rule of thumbs" or flat out "guess".
Sorry for the rant but your queston can only be answered by a good well educated HVAC contractor visiting your home. That type of a contractor is getting hard to find these days in such a price competetive world.
Posted on Oct 14, 2008
  • 17 Answers
SOURCE: 3 amp fuse blows after three hours on Goodman 4 ton 16 seer pump
I would suspect you have a problem in the defrost circuit of your heat pump. there are a couple of things you can try. first just run the system on emergency heat and see what happens. you could have a defrost board that is shorting when it kicks into defrost. it sends a signal back to the furnace so it will come on during defrost. if you do not blow a fuse as long as you are running in emergency heat, i would suspect the defrost control board. also you could have a dead short in the wire that runs from the "w" terminal on furnace control board, out to the heat pump. keep in mind that any of the wires could be the cause and i am just tying to give you the most common things. your furnace will still run if you unhook all the low voltage wiring out at the heat pump. if you do this and stop blowing fuses. you know it is something on that wiring. goodl luck.
Posted on Jan 27, 2009
mastatech
  • 478 Answers
SOURCE: Heat Pump Cycles On and Off and Air Handler Noisy
I am pretty sure you have a low charge and the pressure switch is kicking it off. probably just a pound or two however the accumulater will sometimes hold more.
Posted on Mar 31, 2009
P 1492 obd fault code mahindra Maximo
Take your pick;
Chrysler/Dodge/Jeep:
Ambient/ Battery Temp sensor input voltage too high
Citroen/Peugeot:
APLSOL Solenoid Circuit Malfunction
Ford:
Infinity:
EVAP Canister Purge Control/Solenoid Valve (Circuit)
Mercedes:
Mitsubishi:
Battery temperature sensor high voltage
Nissan:
Purge Control/V S/V
Plymouth:
Battery Temperature Sensor Voltage Too High
Saab:
EVAP Tank Pressure Sens. Value too low when Depressurised and malfunctional fuel level sen
Subaru:
EGR SIGNAL LINE 1 CIRCUIT (LOW)
Sep 27, 2017 | Mahindra Cars & Trucks
I have carrier infinity heat unit split system now my thermostat keeps saying comm error
Unplug the AC unit for 5 minutes to see if it will reset and clear the communication error.
Nov 18, 2016 | Carrier Heating & Cooling
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
Sensor Error on Thermostat for Carrier Infinity System
Either miswired, or incompatible components, or outdoor thermistor isnt installed or is bad
an easy fix if onsite
Aug 23, 2009 | Heating & Cooling
Carrier infinity control SYSTXCCUID01-B sensor communication erro
There should be a little black sensor bulb outside either on the unit normally under the electrical panel or inside it. It sound like the wire has come off or been disconected. It needs that on to properly run. Your control is trying to communicate with the outdoor unit and can not.
Jul 07, 2009 | Heating & Cooling
Carrier Infinity Control Programming Issue
Open the flap, and press and hold the advanced button for 10 sec. you will be in the Installer setup screen. scroll down to the setup subfolder and select thermostat and it will be in there.
Feb 27, 2009 | Carrier Heating & Cooling
Curtailment active
A follow-up to my previous post. I talked with a technician from the Co that installed my unit, and the issue lies in the "Utility saver mode" for the 2 stage heat pumps, and having the high stage locked out. In the Advanced Setup menu (hold the "Advanced" button for 10 seconds to access this menu, look for the "Utility Saver" menu item. Select it and your system probably shows that "Utility Saver" is enabled, which only allows your heat pump to run on the low stage and not the high stage. If you change the the setting to be disabled, this will allow your system to run at the high stage and should solve your problem.
I have not changed the settings on my system yet to confirm this solution. That will have to wait until I get home this evening.
May 11, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
4,794 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
