Question about Frigidaire FRS-26DR7D Side by Side Refrigerator
Compressor i have a frigidaire gallery frig and need a new compressor. The problem is I do not have the model number for the frig. It has a 1/3 hp compressor. Can i use any 1/3 hp compressor that will fit.
  • Frigidaire Master
  • 4,655 Answers
Just have a local refrigeration store to match the numbers on the top of the compressor. It will go by BTU more than HP. Standard refrigerator uses 800 BTU's while side by sides use 1000 to 1200 BTU's..Sea Breeze
Posted on Jun 22, 2009
Frigidaire gallery french door frig power failure generator kicks in and frig stays on Sabbath mode if I am away will my food spoil in this mode when power returns will frig return to normal operation
Good Afternoon Diane,
I understand you want to make sure that if you are away, and your Frigidaire refrigerator is in Sabbath mode, and there is a power failure, will your food spoil or will your appliance return to normal operation. Typically, your refrigerator should return to normal operation, in Sabbath mode. I kindly ask that you provide me with the model number of your refrigerator. Typically, this number is located inside on the left or right hand walls. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Refrigerators
Compressor buzzes loud & frig does not get cold
That can also mean that the starter is broken.which will be a cheaper fix than a new compressor.Also the capacitor can be broken and that will give the same results.
Please click HERE for drawing and parts( #30 is starter #55 capacitor)
Jul 28, 2008 | Frigidaire FRS26R4A Side by Side...
What's wrong with my frigidaire gallery, it wont
What is the model number of your unit? Is the compressor running?
Nov 24, 2012 | Refrigerators
Frigidaire gallery freezer fully thawed and red light never came on.
So lets start with this do you hear any clicking noises coming from behind the frig? Can you hear the fan running in the freezer? Does the frig cool at all?
Sep 25, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a frigidaire gallery series frig side by side with ice and water in door. The frig part won't stay cold. It also seems to take long time to make ice. The frig part works ok for awhile and then...
Check for two things. Look under the refrigerator and make sure the compressor fan is turning.
Second, check inside the freezer for proper operation of the fan that moves cool air throughout the freezer and refrigerator. If this fan is working, you can probably hear it. It should be behind an access plate in the freezer (near the top). Remove the plate and look at the fan. If it's not turning, you will have to replace the fan motor.
Oct 17, 2009 | Frigidaire FRS23KF7AB Side by Side...
Freezer is cold but the frig side is not???
Hi Gotzd,  If you open the fresh food side (not the freezer), and look to the upper left side you will see a plastic shroud or cover. Behind that cover is a printed circuit board (p.c. board)   and a damper motor. That motor brings cold air from the freezer to the fresh food side. The whole damper assembly may need to be replaced. That also includes the cold controls for both sides of the "fridge".  Home Depot Parts and Accessories has the part available. 800.378.5830. Call, give them your model number, and the description, they will locate the part number for you. This MAY be the solution for you, it was for me. Hope this helps, better yet, Hope you've fixed already.
Steve D.,  Owner Handy Home Repair
Jan 17, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Have a frigidaire gallery frig model plrs267zab8....can't get water, ice maker to work after inserting new filter...
generally the filters I have changed need to be flushed with water before acutally using them because carbon can come out of the filter when first used. I don't know you specific item. Check the direction of the filter it may be installed backwards. Can you remove the filter and verify that you get water flow when the valve behind the filter is on? Just suggestions.
Dec 13, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a frigidaire gallery model plhs267Za side by side fridge, I came home today and everything in the freezer has defrosted, it is making a strange buzzing sound on and off.. can anyone help? thank you
I THINK THE BUZZING IS THE COMPRESSOR TRYING TO START,ALSO LOOK ON THE BACK OF FREEZER AND SEE IF THE WALL HAS FROST ON IT,IF IT DOES YOU HAVE A BAD DEFROST HEATER OR TERMINATOR OR IT IS STUCK IN DEFROST,LET ME KNOW WHAT YOU KIND,ALSO YOU SHOULD UNPLUG IF YOU FIND THE COMPRESSOR IS TRYING TO START BUT WILL NOT,PULL OUT FRIG. AND SEE IF YOU HEAR THE CLICKING SOUND,ALSO PUT HAND ON COMP. TO FEEL IF RUNNING,BECAREFUL MIGHT BE HOT
May 30, 2008 | Frigidaire Refrigerators
Frigidaire FRS-26DR7D Side by Side Refrigerator Logo
207 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
