Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Humming noise when turned on
Could this be coming from the fan that is behind the bulb,for sure coming from that area!!! what would be the cost of that fan unit...
  • 11,896 Answers
It is very possible that it is the fan you are hearing. They run constantly running, and their bearings tend to overheat casing a hum noise.
Posted on Jun 22, 2009
What can be causing a loud humming noise from the bulb area of a Samsung DLP television after replacing the bulb?
is the tv still coming on, if not its the bulb is broke, do not touch the bulb it damages it
Dec 20, 2015 | Samsung Televison & Video
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Jan 11, 2014 | Maytag MFI2269VEM 22.0 cu. ft. French Door...
The fan is working but the air blowing is not cool. Sounds like the Compressor tries to turn on I hear buzzing or humming for about 3 seconds then it stops. I was near the fuse box and I think some noise...
you may have a bad start capacitor or windings. You really need to call for a service technician in your area to diagnose the problem. Doing it your self can lead to personal injury or cost you a lot more money to fix.
Jun 19, 2010 | Heating & Cooling
I have a 44 inch 44nhm84 DLP. When the TV is turned on, it makes a loud humming noise that goes down in intesity twice and then finally a lesser humming noise after the picture comes on. At first I thought...
This does sound like a color wheel. To my knowlege, Toshiba does not sell the Color Wheel seporately. In short, you have to replace the Opical Block. The cost of this is very exspensive and Toshiba may not sell it to you. You may have to go through a Toshiba Service facility to obtain it. Check prices of new LCD sets before investing the money.
Hope this helps,
Skyassoc
Jun 18, 2009 | Toshiba 44NHM84 44" TV
My Samsung RS263022 fridge makes humming noises that comes and goes. One day it will hum, the next it won't. The time the noise varies. Listening to the humming, I can tell it is coming from the back....
The most common problem is the condenser fan, if it has one. It may need cleaning and or oil. Most of them do not have a place to be oiled. The fan can be replaced cheaply. Make sure the power cord is unplugged before taking the cover off of the compressor and fan area.
Nov 26, 2008 | Samsung Refrigerators
Humming inside the switch
Is it connected to a fan motor also? - most dimmers are for lights only - if there is a ceiling fan connected you may experience a humming sound from the dimmer
Nov 12, 2008 | Lutron #D-600PH-DK 600W SP Push Rotating...
Maytag MDB5000AWW started making noise when cleaning. Bottom arm working , but water isn't pumping with much force. No water coming out of top hole (removed arm to make sure there is no obstructions. ...
HI Motor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.
Sep 12, 2008 | Maytag Dishwashers
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
Toshiba 46HM95 Buzzing
I have the same thing, mine is the cooling fan for the lamp. If the sound continues for a short time after you turn off the TV then this is the most likely cause as the cooling fan will continue to run for a short time to cool off the bulb. I have looked into replacing mine, the part runs around $50 but I can't say yet how easy it is to replace yet.
Apr 02, 2008 | Toshiba 46HM95 46" HDTV
Loud noise
I believe it is the color wheel. The motor might be going bad or it has dirt or dust in it.
I hope this helps
Shuttle83
Nov 06, 2007 | Toshiba 62HM95 62" HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
108 people viewed this question
Jerry Greenberg
Jerry Greenberg
