Question about Refrigerators
I have a 521 ltr E521TRB refrigerator which is leaking from inside the fridge. The plastic fitting for the internal 'drainpipe' (behind the main panel at the rear of the fridge) has broken away from the top of the fridge compartment. Can this be glued or do I need to buy a replacement part to repair this problem?
    Sergeant:
    Champion:
  • 208 Answers
You need to buy a replacement part
Posted on Jun 22, 2009
I have a 16 year old fridge westinghouse frost free model RJ275M 275 ltr. The freezer is working great but the fridge head stopped. inside the actual fridge there is a leak. Any help would be great on...
what? do u speak english?
fridge head? stopped? what is that?
what leak inside the firdge? leak of what where?
any help would only help someone with a clue.
you need to CALL A PROFESSIONAL
Dec 26, 2014 | Refrigerators
My refrigerator has a smell that it never had almost like plastic.it is about 10 years old
the smell on your fridge sounds to me like its leaking.inside your fridge is surrounded by a type of gas that helps to keep your foods cool.once the side walls of the fridge have been penatrated the gas leaks out. in my experiance the unit is unreparable and fit for the bin
Apr 23, 2011 | Maytag Refrigerators
My Samsung RS253BAWW has been collecting water underneath the bottom drawer for some time now. It eventually winds up in the drip tray underneath and then runs out onto the floor. I've replaced the...
Depends if there is plastic tubing running inside fridge compartment. Shut off water to fridge. If that stops it you will have to look inside to see if there is visible plastic water tubing or if you can get to it from inside the fridge. Maybe the water line has a defect or got pinched and somehow split. Then turn on water, find leak and splice in a replacement section.
Jan 28, 2011 | Samsung RS2534 Side by Side Refrigerator
Im having a problem with the fridge not cooling. the ice box works just fine and i have the controls on max but its not cooling down
See if the compressor is running. its under the fridge and will be humming. If its running you fridge and the fan under the fridge is running also then your fridge is low on freon. If the fan is now running replace it. If the compressor is not running it could be the starter which is inside the plastic cap on the compressor. It is a nickel size part connected to one of the 3 prongs on the compressor. It also could be the timer. The timer is a device that turns to fridge defrost. It is located behind the plastic in the top,back of the ref side of the fridge or behind the back in the freezer or under the front bottom underneath the fridge. it will have a slot near its center that a flat blade screwdriver can fit in turn it slowly and you will hear audible clicks the compressor should kick on if not its not the timer. good luck
Aug 12, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Water is leaking onto the inside floor of the fridge. when u used the water dispenser it leaks even more
You have a leaking water tank inside the refrig behind the crispers . The tank ( now plastic hoses ) is easily replaceable . Called a water resevoir technically .
May 12, 2010 | Refrigerators
Found a leak behind fridge,plastic hose is seperated
There is no connector . The plastic line pushes into the valve . If enough line is there , remove the short piece from the valve by pushing in on the white ring while pulling out on the broken line , and insert the main line into the valve with a little force . Check for leak by using water dispensor.
Aug 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The refridgerator has large amnts of water leaking from freezer
Looks like your defrost element is bad and needs replacement. Or if you can do a manual defrost and check if you are getting heat on the element. If there is heat, you can find a piece of copper wire and wind it around the element, leaving a trailing length of around two centimeters into the outlet drainpipe. By conduction this should keep the drainpipe clear.
Jul 02, 2009 | Refrigerators
WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
We have a leak in the back bottom of our refrigerator , ice maker
You say there was a new copper line attached? I assume that this means a repair has been done. If the unit has been slightly overcharged with refrigerant, this can cause excessive condensate to build up on the return copper tubing and would then drip in the back of the fridge. Or you should check on the drainpipe which often has a drainpan built either over the compressor dome or somewhere within the compressor area. Make sure the drainpipe is not missing the pan and that the pan is not leaking.
Mar 09, 2009 | GE 17.2 cu. ft. Top Freezer Refrigerator...
In stalling the main water line from my home to the fridge
Generally the connection to the refrigerator ice maker from the home water system is in back of the refrigerator in the lower right corner. There is a one quarter inch compression type fitting where the water is connected.
Jun 07, 2008 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
