Question about Yahoo Messenger
I am unable to follow links to yahoo profiles on yahoo messenger.
I get an error message saying I need to go to my control panel and then go to folder options and select a program to execute the links. But I do not know what settings to change once I am in Folder Options.
  • poa1583 Jun 22, 2009
    I am unable to follow any link sent to me. I can not open an email alert, the help tab on the buddy list (Pressing F1), anything that requires me to be forwarded to a website.
  • ohTerrbear May 11, 2010
    are you having a problem loading certain applications or extensions like .doc for word?
  • 55 Answers
Good day.Your problem is that you have downloaded the yahoo installer and your computer doesnt know which installer to choose for your package.Go to the folder options and bind the .exe applications with the istaller icon or executable files.
Posted on Jun 22, 2009
I can't download yahoo messenger...:(so_so_lino@yahoo.com
Are you getting an error message when trying to download the Yahoo! Messenger? If not, try to download the YM using the link below:
http://messenger.yahoo.com/download/
Observe if you'll get an error.
Thank you and good luck!
Aug 05, 2010 | Yahoo Messenger
Download yahoo messenger
I think you would have started to download the yahoo messenger from a suspicious website. That might be the reason why you are getting some plugin errors.You can always register for free in the website provided below .Just go to the link below and download the Yahoo! Messenger software:
Upon starting the installation process, just click the "Get a new Yahoo! ID" link.
Thank you !!
Jun 07, 2010 | Yahoo Messenger
Hi there this my problem "Yahoo! Messenger is...
You need the following OS to support Messenger
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64 / Windows7
If that is not an issue read on.
The problem is probably due to a mal-function of the uninstall software.The Yahoo Messenger uninstall software is notorious for leaving files and fragments behind creating conflicts with the incoming software
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall the old Yahoo Messenger program from the Control Panel and failed to back it up with a visit to the 'C' drive, you may have old software conflicting with the incoming software trying to share the same folder.
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
If you have Vista you may be denied being able to delete folders - in this case you will have to disable the 'User Account Control'
Start > Control Panel (Home) > User Accounts and Family Safety > Add or remove user accounts > Continue > Go to the main User Account Page > Turn User Account Control On or Off > Continue > Uncheck control box > OK
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
Re-start your computer
Download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
May 20, 2010 | Yahoo Messenger
Unable to run messenger
Its a pity you chose to re-install - a simple toggle of the connections from 'Direct' to 'Proxy' was probably all you needed.
As for your current installation problem:-
You do not need to adjust your firewall for uploading Messenger
Check
May 07, 2010 | Yahoo Messenger
Application error occuring to install or remove yahoo massenger?
Check
Re-start your computer and download Yahoo Messenger from here.
Failure to initialize error message persisting? try this download site
http://download.yimg.com/ycs/msg/dl/msgr10/us/ymsgr1000_525_us.exe
Jan 09, 2010 | Yahoo Messenger
Yahoo Messenger Initializing Prob
Check
Failure to initialise error message ? try this download site
Jan 07, 2010 | Yahoo Messenger
Trying to download yahoo messenger but I get an error that says something like this: applications has failed to start because the application configuration is not correct. Anyone have an idea why its doing...
Check it out with down loading installation path and as well previous versions of YM on your system along with other Messengers with out error
Dec 12, 2009 | Yahoo Messenger
Why can't I install yahoo messenger 10.0 successfully? after attempting to install, an error will prompt which says ''yahoo messenger did not install properly; this may be due to an open application or...
Windows 2000/XP/2003/Vista/XP64/Vista64
The problem may be due to a mal-function of the uninstall software.
If you tried to uninstall from the Control Panel and failed to back it up with a visit to the C drive, you may have old software conflicting with the incoming software trying to share the same folder.
Check
Download 'ccleaner' and run it through a couple of times.
Nov 20, 2009 | Yahoo Messenger
Yahoo Messenger Logo
Top Yahoo Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
