Mitsubishi WS-65809 65 in. Rear Projection Television
Problem for Mitsubishi WS-65809 65 in. Rear Projection Television
Ws 65809
By darinpham on Jun 22, 2009
ws 65809 wont power up at all Any suggestions to fix this Thanks problem?
Comments:
Jun 22, 2009
- I get nothing.
Jun 25, 2009
- I am not getting any response when I hold the to buttons down. What are my next options. Thanks!
Jul 03, 2009
- the power led light doesnt power up at all. Thanks for your help with any suggestions.
Aug 20, 2009
- If this is the problem I am having with my tv. Do you think its worth fixing or should I give it up. I hate to spend much on the tv. But, I also hate to buy a new tv. I think this tv's picture(when working) is really good. I actually prefer it to the lcd upstairs. Thanks for your thoughts.
Aug 21, 2009
- thanks for the advice. Where are the fuses located and what do they look like? Thanks so much for your advice.
Aug 21, 2009
- could the STK392-570 prevent the tv from powering up? when I plug in the tv, it sounds like it is working. But it doesnt power up when I press the power buttom. One of the STK392-570 solder is loose and pretty sure one of the point looks a little burnt. Thanks you so much for the excellent advice.
Aug 21, 2009
Aug 21, 2009
- great. Where do you recommend purchasing a ic? first, i will try to resolder it and that fails i will purchase a new one. Thanks so much, I truly appreciate your help!
Aug 21, 2009
Aug 21, 2009
Aug 22, 2009
- I have very little lubricant or grease on the ic's. What can I use to grease them up or will they be fine? Thanks..
Aug 22, 2009
- ok, i resoldering the ic's and it sound like it should come on. But, I still get nothing. Any new suggestions before I order 2 new ic's?
Aug 23, 2009
- removed the ic's and still no power. What do you recommend next?
Aug 24, 2009
- what color would the substance look like on the boards? I do see some whitish compound on it. The same stuff i put of the ic's. Also, I am looking at another mits 65" and the guy says, The sound works and no picture. What do you think might be the problem with it? Thanks for all of your advice.
Aug 26, 2009
- I dont see any signs of coolant leakage. What might I check now?
Best Solution
posted on Jun 22, 2009
Very Helpful)
Slinteriors
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 3847 votes
does the led blink a two digit blink code when you press the menu and device/input buttons both in together for 6 seconds? If so let me know the two digit blink code and i will assist you.
Comments:
Jun 25, 2009
- Does the power led light up when you press power? If it does and you still get no error code, then that means the microprocessor isnt operating, So I would suspect one of the low voltage regulators or possibly a diode which is preventing the set from powering up
Aug 20, 2009
- I would suspect one of the fuses may be blown since you get no power indicator light what so ever. Check the fuses one or more may be blown
Aug 20, 2009
Aug 21, 2009
- They are located on the board located on the far right looking in the rear of the set. They are just small Glass axial fuses.
Aug 21, 2009
- Yes the STK392-570 can definately prevent the set from working and if its loose that may very well be the problem as the IC could be shorted due to its being loose.
Aug 21, 2009
- You can get replacment ICs at the following link.
http://servicemanuals.vstore.ca/
Shipping is free if you live in the US
Aug 22, 2009
- Radio shack part #276-1372 its 1.29 per tube its called silicone base Heat sink
Aug 23, 2009
- I would try removing both the ICs then try powering up the set. With the ICs removed the set should power up if the ICs are the cause of the set being dead.
Aug 24, 2009
- If that doesnt let the set power up. The next thing I would check is to see if you can see any sign of CRT coolant that may have dripped onto the boards as that is a very common fault as well in that model. The CRT coolant may appear as a stickly pasty substance on the boards a strong flashlight held on a angle will usually show signs of coolant leakage.
Aug 24, 2009
- Its colorless its appears as a sticky pasty residule. If a mitsubishi has sound but no picture its a vertical failure most likely. The vertical IC may need to be simply resoldered.
Aug 28, 2009
- you would need to check the stand by voltages to see if any of them are not as specified in the service manual for your model, as it may be a low voltage regulator that isnt operating properly.
Was this helpful?
Yes
No
3 people thought this was helpful
Asker's Testimonial
" Excellent advice. I appreciate your expertise. " - darinpham
Popular Solutions for Mitsubishi WS-65809 65 in.
Questions and Unsolved Problems for Mitsubishi WS-65809 65 in.
Do you recommend Mitsubishi WS-65809 65 in. Rear Projection Television?
Answer
Answer
how do i hookup the surround sound so that all electronics run through tv to surround speakers any... (More)
Answer
How do i hookup up a blu-ray player to my mitsubishi tv model# ws-65903 cable on back of tv is... (More)
Answer
mitsubishi ws65907 picture comes on then goes black sound works. picture comes back temporally when... (More)
Answer
I have a Mitsubishi WS-73903, I need a Mitsubishi HDTV coverter box to get 1080i up grade from 480i
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
