Question about Maytag MDB6000 Dishwasher
Maytag dishwasher that won't drain when finished
My Maytag MDB6000AWW dishwasher has about 3 inches of dirty water in the bottom of the tub after it is finished that won't drain away. It does not flood therefore it must drain some. I took apart the screens inside it and cleaned them, I have also checked the drain hose and it is clear. Now what?
  • 6,784 Answers
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Jun 22, 2009
  • 439 Answers
Ok, I assume you are the one from earlier. There are only two other reasons for this to happen, ok three but one should be clear. The sink is backed up or backs up as the dish washer drains. I doubt this is it as you already cleaned the hose. The other reasons could be the drain solenoid is not working or the drain pump itself. Other than that it would be the timer, but again that is highly unlikely. The reason you are not flooding is there is a float switch inside the dishwasher that lets it know how much water is in the tub. You can "jiggle" it (the float) and see if that helps.
Cycle does not finish leaving dirty water bottom of tub without draining out
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 12, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
We have a MDB6000AWW model d/w. It is leaking
Yes what happens is it gets past the rubber seal somewhere higher during the cycle and gravity pulls the water down to where you see it leaking. 11 years is a good lifespan of a door seal. Plus they are easy to pull out and replace. Just yank it out and push the new one in. Hope this helps.
Jan 25, 2010 | Maytag MDB6000 Dishwasher
Dishwasher has terrible smell and water lays inside tub.
The drain is plugged. You will have to pull out the dishwasher and clean out the drain port. A repair person could also do this for the price of a house call. The smell is coming from the dirty water in the tub. You'll have to bail this out before making the repair.
Jun 29, 2009 | Maytag MDB9600A Jetclean II Built-in...
My dishwasher will not drain. I have taken it apart and cleaned the screens but it still will not drain. Any ideas? It is a Maytag MDB6000AWW
More than likely it is your food disposal. Remove your drain line from the disposal and clean and inspect it, then clean out where it connects in the disposal. This should allow it to drain, if not remove the drain from the bottom of the dishwasher and clean it out there. This should fix your problem.
Jun 21, 2009 | Maytag MDB6000 Dishwasher
Maytag mdb7100awb dishwasher is leaking from the bottom right corner. starts to leak almost immediately upon starting it. I then opened it and found that the entire tub is filled with water, looks like it...
take off the bottom panel there are 4 screws you got take they are 1/4 inch screws  once the panel is off turn on the dishwasher and see where exactly the leak is coming from
Jun 07, 2009 | Maytag MDB7100AWB Dishwasher
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Maytag MDB4100 Dishwasher - Water Does Not Drain From Tub
go to managemyhome.com and pull your manual up from there.
Dec 19, 2008 | Maytag 24 in. MDB4100 Built-in Dishwasher
Dishwashers Logo
883 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
