Question about Spa Parts Plus GFCI, Circuit Breaker, 30 Amp
Hooking up a Hot tub
I just got a old 2-3 person hot tub. The pump moter is a 16.4 amp11 volt I believe the heater controller is as follows:
Porter & Blumfield
> KUP 14A15 - 120
> 120V 50/60 Hz
> Industrial Rated
> 3A 1/hp 600 VAC
> 10A 1/3 hp 120 VAC
> 6 2/3A 1/3 HP 250 VAC
> Appliance Rated
> 10A 250 VA
The previous owner did not have a GFCI breaker in the connection. He was using 10/3 with a ground wiring to a subpanel.
What size and type of GFCI breaker do I need. (ie 30 amp 2 pole or a 30 amp 1 pole breaker)?
  • krabach Jun 22, 2009
    So what you are saying is I can use a 15 amp GFCI breaker with the motor on the pump that is a 16.4 amp /115 volts and the heater in the box by the hot tub?
    Also what size breaker should I use in the main breaker box?
    Thanks
  • krabach Jun 28, 2009
    The heater plate on the back side of the heater control 5.5KW 240v
    The pump motor is 115 volts / 16.4 / 4.4 60 Hz,
    There is a 30 amp what appears to be a breaker in the wiring box, I have attached a photo of the wiring box that is located under the spa.
  • 770 Answers
Everything above tells me this is 120V unit...if thats the case a single pole breaker is sufficient. Also by what you have written, a 15 amp breaker should suffice.
Posted on Jun 22, 2009
  • Hal Hallman Jun 22, 2009
    No..apparently I missed that in the first post. You will need to go up to a 20 amp for the motor. You can add all amperage to know what goes in the box, if it is all on the same circuit. If you use a ground fault breaker in the box, it is not necessary to use one at the hot tub. I would suggest that you cover everything at the box and wire a disconnect at the tub. Make sure the tub is properly bonded and grounded, I would hard wire everything from the disconnect.
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
Water sensor needs to be replaced. 8 yr old unit. Maax doesn't carry old parts unavailable HELP PLEASE!
Parts for Maax Spas‎
www.spaguts.com/
(714) 764-0014
Pumps, packs, heaters, controls,
ozonators for Maax hot tubs.
# 27 Hot Tub Heater Replacement for 240 volt hot tubs ...
? 6:27
https://www.youtube.com/watch?v=xNWjM8c_b-8
Oct 10, 2011 - Uploaded by softcellelectrical
27 How to replace an in line or flow through heater for an above ground ... I just changed out the water in my spa when I discovered the heater element ... Is there a hose that should fit on it? ... I figure it will run similar to a whirlpool setup. ... tests on the unit...but, it sounds like 1. your sensors may be DC and
Jan 18, 2016 | Maax Home
Wiring motor hot tub
The wiring diagram should show on side of motor.
Here is basic motor wiring:
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Test each lead as shown in following image. In the case of 240Volt, the 2nd wire is not Neutral, but testing is same.
http://waterheatertimer.org/images/Motor-capacitor2-800.jpg
If you have 2 speed motor, then you will have switch or timer controlling the speed:
http://waterheatertimer.org/images/GM40-wiring-2-speed-pump-400.jpg
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 05, 2012 | Waterway 5 Hp 230 Volt 2 Speed Side...
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
Feb 22, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a 2000 Sovereign Hot Spring hot tub that quite heating, I checked filters they are ok, I have no air lock, The jets and light work fine. Inside the control box on the circuit board all 3 led lights...
Check for a bad heater controller board or burnt wire connection going to the heater. You can check for voltage across the white and black leads going to the heater from the heater controller board (upper left corner of the black control box
Mar 31, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
Jet pump will not shutt off after I replaced heater relay. Tub is a hot springs landmark with an IQ2000 panel the year is also a 2000
it sounds like the pump relay may be stuck closed. Also check the temp readout, if it thinks the water is too hot it will try to cool the water by running the jets and sometimes the blower as well.
Dec 08, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
How long does it take to heat the tub
Make sure that the inline heater has power. It should not take very long to heat since your putting hot water into it anyway. The heater is to keep water warm.
Jul 02, 2009 | Waterway 1 Hp 115 Volt 2 Speed Side...
Spa Parts Plus GFCI, Circuit Breaker, 30 Amp Logo
417 people viewed this question
Top Spa Parts Plus Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Spa Parts Plus Electrical Supply Expert? Answer questions, earn points and help others
