Question about Compaq ( 234894-001) (  234894-001) Motherboard
Compaq Presario SR2010NX beeping
My computer is making a beeping sound constantly. I took the RAM sticks out to replace them, and when I put them back in, the computer isn't reading it I guess.
  • ragnarokkinn Jun 22, 2009
    as in a pencil eraser? I don't see how that would help? I've taken them out and put them back in before, just for some reason it stopped reading them. If it helps any its DDR2 512MB, two 256mb card. My computer is a bit dusty inside though.
  • mnguy7764 May 11, 2010
    Did you take them out and reseat them again? If you have, try it one stick at a time, perhaps you have a bad stick?
  • 35 Answers
Sometimes using an eraser over the metallic part of the RAM stick can get it to be read to the system..i have tried it many times it works
Posted on Jun 22, 2009
  • ananimesh
    ananimesh Jun 23, 2009
    sometimes the metallic part of the RAM stick is dirty.coz of this there are times that the RAM stick cant be read.i have done this.used a pencil eraser over the metallic part of the RAM stick.if the problem is coz of the dirt/dust,this cud probably help u....
Installed lynex on my compaq presario sr2010nx and i cant get the sound to work
Make sure the audio drivers are in the device manager. Make sure the volume is turned up and not muted. Look at the Audio/Sound properties in the Control Panel and make sure they are not muted and the volume is up. Make sure you have the speakers plugged into the light green port on the computer and that the speakers are on and the volume is turned up.
Apr 11, 2012 | HP Compaq Presario SR2010NX PC Desktop
Compaq presario m2000 notebook continuously beeps while starting up. The computer is very slow once fully logged in. Do you have any suggestions to fix these problems?
The beeping usually points to a RAM stick failure. If your laptop has two sticks of RAM then one of them has failed, which further explains the slow performance of the laptop once it's fully loaded.
To troubleshoot this issue, you'll need to remove one RAM stick at a time, and see if the laptop boots at all. When you have only one stick of RAM and the laptop does not load after the beep signal, then that installed RAM stick is bad. You may want to try and clean up the contacts with a cotton cloth and some alcohol just to make sure it's not an oxidized contact issue.
If this was informative and helpful please vote with a Thumb Up. Thank you.
Feb 01, 2011 | Compaq Presario M2000 Notebook
Compaq Presario S5100NX Desktop PC 1 LONG BEEP AT START UP I GET THE COMPAQ LOGO BUT NOTHING ELSE. THANKS FOR ANY HELP.
One long beep usually means a memory or RAM error..
Try removing the ram sticks and then simply replacing them back into the slots..
The contacts in the RAM slots are self cleaning to taking the sticks out and putting them straight back is usually enough to correct this issue..
Just make sure you touch part of the metal chassis of the tower BEFORE you touch anything else.
This will discharge any static charge you may have on your body..
Dec 19, 2010 | Compaq Presario S5100NX (E120866) PC...
All cords connected - switch power on - constant beeping sound - nothing on screen - states no signal
if ur getting a constant beeping sound then the problem can be with the ram cards so u need to ope the pc and check with the ram cards first of all
Jul 17, 2010 | HP Compaq Presario F750US
Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
Feb 12, 2010 | HP Compaq Presario SR2010NX PC Desktop
Hello, my Compaq SR2010NX has had a nissue in rebooting with no video output for a few weeks now, getting worse as time goes by, repeat boot and turning on monitor at specific timestamps in boot up helps...
Hi friend,
Your system RAM is faulty,please replace the RAM with another RAM or if you are using 512/512 MB two RAM,remove the RAM vise a versa(one by one) and check.
Thanks,
Jan 28, 2010 | HP Compaq Presario SR2010NX PC Desktop
I have a presario 3017cl, when i turn it on the screen is black and it beeps constantly
Need to know the specific number of beeps to analyze this but all computers need three things to fire. Ram memory, CPU and video. Those are the root of most beep codes. Check your ram memory sticks and make sure they're fully inserted in motherboard. Make sure the video card is inserted properly if it's not an onboard video. If it's not one of these then you probably need to find a professional and it's a pretty good chance the motherboard may be bad.
Oct 29, 2009 | Compaq (325489-001) for presario 3000...
When turn on...just beeps constantly with no video or startup at all...
could be bad power supply or maybe ram sticks dont have a good connection, unplug the computer and check all connections re-seat the ram sticks and hope for the best.
Oct 18, 2009 | HP Compaq Presario SR1620NX...
PC dose not turn on just Constant 3 beeps
ok u have to change your ram because this 3beeps is the ram problem indicate.. first u have to change your ram...
Mar 31, 2009 | Compaq Presario sr1403wm AMD Sempron 3000+...
Computer desktop problem (CPU)
You need to change your RAM. Get a friend who has experience of computer hardware, to open your computer and take out the sticks of RAM, which you can then take to a Computer store, in order to purchase a replacement. It is necessary to take the sticks of RAM with you, because it important to put the correct type of RAM into the machine, otherwise you can damage your computer irreparably.
Hope this helps
Chris (ziraffa)
Jan 13, 2009 | Compaq Presario S5000NX PC Desktop
Compaq ( 234894-001) (  234894-001) Motherboard Logo
199 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
