Question about Taylor & Digital Scale Lithium Scale
Inaccurate Readings I'll weigh myself then step off the scale and wait for the reading to clear and the scale to turn itself off. Then I step on again immediately and the reading will be up to 1.6lbs lighter! What's happening and how can I fix it?
  • inmnf321 Jun 22, 2009
    P.S. i'm not sure what model is... 7402 maybe
    Sergeant:
    Champion:
  • 208 Answers
Time to buy a new scale :)
Posted on Jun 22, 2009
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
    My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
    The manual is short and PASTED after link to same here:
    http://digitzscales.com/index.php?option=com_content&view=frontpage
    Digitz DZ3-600 Manual
    I. Operation
    1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
    2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
    3. Place the quantity to be weighed onto the weighing platform.
    4. Wait a couple seconds for the display to stabilize before taking a weight reading.
    II. Changing the Unit of Measure
    1. Press the MODE key to change the scales displayed unit of measure.
    2. If the scale is turned off then back on, it will default to the last unit used.
    • DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
    • DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
    III. Using the Tare Feature
    You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
    1. Place the empty container or vessel on the weighing platform.
    2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
    3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
    4. To return to normal weight display (gross weight), remove any items from the weighing platform and
    press the TARE key again to re-zero the scale.
    IV. Calibration / Adjustment
    1. Turn the scale on by pressing the ON/OFF key.
    2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
    3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
    4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
    V. Error Codes
    1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
    2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
    3. L - Batteries are low. Replace the batteries.
    VI. Specifications
    DZ3-100 DZ3-600
    Max. Capacity 100g 600g
    Readability 0.01g 0.1g
    Min. Weight 0.03g 0.2g
    Power Two (2) AAA Batteries
    Dimensions 3.0 x 5.0 x 0.8 in.
    Platform Dimensions 2.5 x 3.0 in.
    For warranty and support, please email
    warranty@digitzscales.com
    Aug 20, 2014 | Office Equipment & Supplies
    Re MiBody 360 Personal scale. downloaded software successfully (Windows XP) inserted USB into scale and stepped on . waited for a few seconds then put USB in PC but no data transferred (PC recognised USB...
    Make sure that you have selected USR1 each time you weigh yourself.
    When you stand on the scales it records your measurements against that user ID and holds them in the internal memory of the scales.
    When you have taken a few readings and when you are not standing on the scales, insert your USB memory stick (any memory stick will do) and press the SET button. The scales display "USB" and write the data out to the memory stick and gives you a message "END" afterwards. When you insert the memory stick into your computer you can read the data into the Homedics software
    Aug 26, 2013 | Health & Beauty
    Escali scale wont turn on
    Step on the scale and immediately step OFF and the scale will then be ready to weigh you. If this does not work, then you need to replace the battery.
    Apr 05, 2013 | Escali BFBW200 Body Fat/Water Bath Scale
    Gives me diffrent weights even though I am weighing myself within seconds of time, and in the same spot on the floor.
    I've found I have to weigh myself, step off, weigh myself with something in my something heavy in my hands, then weigh myself again. The 3rd weight you get will be your correct weight. If you needed the manual, I have uploaded in into photobucket...although it doesn't really address this issue.
    http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
    Amy
    Jan 07, 2011 | Taylor 5568 Fat Scale Stainless Steel ()
    This is a new scale. Every time you get on it a new reading?
    See if this helps.
    Step on gently and stand very still. Step off and press/tap with your foot the center of the scale to reset to 0.0 and step up again and be very still while it reads your weight.
    Mine gave a little different weight but after I tried again I had two readings the same and the readings were what I expected. So if in doubt I read twice. If I am very still when I step up mine give same reading.
    I hope there is nothing wrong with your new scales.
    Happy weighing.
    Aug 15, 2010 | Conair Large Digital Display Memory...
    When i try to weigh something on it it displays 'our2'. And does not work
    OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
    May 16, 2010 | Microwave Ovens
    Taylor & Digital Scale Lithium Scale  Logo
    581 people viewed this question
    Top Taylor Health & Beauty Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
