Question about Sony PlayStation Portable (PSP) Console
Update failure0-screen frozen
Tried to update ver 3.95 but update failed and screen frozen. Please advise!!!
    Sergeant:
  • 321 Answers
If you dont have the charger in while updating your battery can die and then ur psp is left with no brain.. you can unbrick it but you need to get step by step instructions from me
Posted on Jun 22, 2009
Home screen frozen and cannot login after automatic update installation, pls advise
If it is windows then boot your pc in safe mood by pressing F8 key at the boot screen and once you are logged on restore your system to a date before the update
for further information please visit
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/app_system_restore_hss_safemode.mspx?mfr=true
Jun 07, 2011 | Computers & Internet
Garmin froze with a "Map Update Notice" the screen
The unit isn't frozen. If you tap the power button you will hear it beep and change screens. What has happened is your touchscreen has failed. This is a common problem. Your touchscreen needs replaced. If you want some troubleshooting info, please see this link. There is just too much info to retype here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Mar 20, 2011 | Garmin Nuvi 660 GPS Receiver
Magellan screen frozen
assuming you have the 2200 as listed in your category, depending when your 2200t was made, it could either have a push type (one you would use a paper clip to reset) or a slide switch.
both are located in the same position (on the left side, bottom under the flap right under the sd card slot)
turn on the gps till you get to the warning screen, then reset it.
if its is the early model with the slide switch, youll have to move it back to the other position and restart it..
if that fails, i would try the latest update, well actually i would install the update either way, whether the reset works or not.
you can get the update HERE
let me know if you need further help
bill
May 24, 2010 | Magellan RoadMate 2200T GPS Receiver
Screen starts to flash on websites
Update video card drivers, run DXDIAG - check your DX version - update if necessary ( I presume you use Windows, DX ver.depends on your Windows version - XP,Vista,7, Try reinstalling Adobe Flash
Nov 15, 2009 | Acer Computers & Internet
DOWNGRADE BACK TO VER 1.3 FROM HAVING UPGRADE TO VER 1.4
u need to get a new cart.
Try getting the "Hyper-r4i" they seem to already have a patch.
cost is about $20 w free shipping
Aug 15, 2009 | Nintendo DSi Black Console
Magellan maestro 3100 frozen on blue screen tried power on and off and reset button still frozen black bar at bottom of scren stays on blue screen
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Jul 14, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Sony driver update
You can down load the driver for vista of sony DCR- DVD 100E/DVD 200E from the following links
This chart provides compatibility information for software that ships with Sony digital cameras and camcorders.
Note: Not all software applies to all models. If uncertain, please refer to your product manual to determine which software came with your model.
Software Compatible Additional Comments Movie Shaker™ software Ver 3.1 for MICROMV camcorders No N/A Nero® Express 6 No N/A Pixela ImageMixer™ for HDD Camcorder No Please update to Picture Motion Browser Ver. 2.0.11
Note: This software is not applicable to all models. Pixela ImageMixer Ver 1.0 No N/A Pixela ImageMixer Ver 1.5 No N/A Picture Motion Browser Ver 1.1 Yes Some behavior may be different from that of the previous Windows XP operating system environment. *3
Please install the update program for Windows Vista. Picture Motion Browser Ver 2.0.01 – 2.0.06 Yes Some behavior may be different from that of the previous Windows XP operating system environment. *3
Please install the update program for Windows Vista. Picture Motion Browser Ver 2.1.00 – 2.1.01 Yes N/A Pixela Picture Package™ software Ver. 1.0 – 1.7 No Please update to Picture Motion Browser Ver. 2.0.13
Note: This software is not applicable to all models. *2 Pixela Picture Package™ software Ver. 1.8 No Please update to Picture Motion Browser Ver. 2.0.12
    *1 It is not possible to save RAW files in the SRF format with the Image Data Converter SR software.
    *2 It is not possible to create a Video CD using Picture Motion Browser.
    *3 Examples of behavior variances:
    Display -
    • The Picture Motion Browser short-cut icon may become a Windows-standard icon.
    • The tooltip information window may not be transparent.
    • images may not be displayed properly in the browser window while playing back movies.
    • Some images, character, and icons may not be displayed properly.
    Sound -
    • The volume control bar in the browser may not be operational when playing back movies.
    • While playing back movies the sound may not be output.
    Other -
    • Some folders, such as public folders, cannot be registered as Viewed folders.
I hope this will solve your issue.
Good Luck
If my solution proves useful please accept it.
Regards
Arjun
Mar 30, 2009 | Video Cameras
Usb ver update
There is no available update for the USB that was already designed for the manufacturer that you can only avail 1.0 version.
Please don't rate me Inappropriate if you don't like my solution or rate me SOLVED if you accept the reality. Thanks
Nov 23, 2007 | Q-Lity 810E-T (P3810E-T) Motherboard
Not working
If your player is frozen. Press and hold the menu button until it turns off and try to update the firmware of the player. And also it may be that the songs on your player is causing the problem try to format the player. How to update the firmware of the player please follow this steps. 1.Slide the hold switch for it to show the orange/red color. 2.Press and hold the record button and the menu button until it shows on the player screen Welcome to recovery mode. 3.Download and install the firmware update. 4.When the firmware update has been installed hooked the player to the computer and perform the update. Hope this helps. :D
Jun 11, 2007 | SanDisk Sansa e250 MP3 Player
Sony PlayStation Portable (PSP) Console Logo
129 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
