Question about Briggs & Stratton Prosumer 20324 Gas Pressure Washer
2700 Series Presser Washer, and I need to change the "engine" oil. There on two oil "yellow" fill point, and the manual talks about changing the pump oil. How exactly do I change the engine oil?
  • 1,305 Answers
Look for a drain plug on the base of the engine.
Take the fill cap off also, and it'll drain easier.
Posted on Jun 22, 2009
What of oil to change on the 2700 PSI Brigg & Stratton enigine? On a "Generac pressure washer" and also what type of oil and how to change the oil on the pressure washer pump.
id your engine model and consult the briggs site........
the oil in the pump is filled during assembly so it doesn't have a nice pair of fill and drain plugs
briggs :
http://www.briggsandstratton.com/eu/en/
Jun 25, 2013 | Garden
Does the machine need an oil change, if so how often and can i do it myself?
i would change the oil every 100 hours or six months in the engine.
and would change the oil in the pump every 12 months.
to change the engine oil,look for a 12mm or 13mm bolt at the base of the motor.
it should be at the front of the engine.undo bolt & drain oil into a container.
tighten bolt up & fill engine with new oil.
Dec 09, 2010 | Northstar Pressure Washer 3000 PSI
What type of gas does it take
Is this a big power washer as shown in the photograph?
Is there a separate place to put oil for engine and pump?
If your engine has a place to put oil, then the engine takes ordinary gasoline
If you have a small engine like a weed-eater or chain-saw, and there is not a separate reservoir for oil, then you mix 2-cycle engine oil with the gas in a 40:1 ratio
Pressure washer oil:
Pump fills about half-way up with SAE20 or SAE30 non-detergent motor oil
Engine fills half way up dipstick with 10-W-30 motor oil
Oct 15, 2010 | Mi T M WP-2700-4MHB Pressure Washer
How many ounces or quarts of oil do you put in the engine and what kind when changing the oil?
Power washer needs oil 2 places.
The pump head has a plastic window on side of pump. Oil should fill to middle of that window. Pump should have 20 or 30 weight NON detergent oil. SAE20 SAE 30 I believe. Auto parts store will know which is NON detergent.
The engine oil is ordinary 10W30. We used to change oil after each painting season by tilting engine to the side. Do not turn engine on it's side or upside down or oil will run into carburetor.
I don't remember exactly how many quarts we put back. Maybe 2? Fill up reservoir until oil is about half-way up dip stick.
Oct 07, 2010 | Simpson PowerShot Commercial-Duty Gas...
How do i put oil in my pressure washer and where thanks
gasoline-powered pressure washer needs oil in two places. The pump and the engine.
Please read your manual along with this information.
Also stop by small engine shop and double-check details.
First the pump: Pump is where you attach hoses.
-On side of pump is clear window you can see oil. Oil should fill about half way. Do not fill entirely.
-Open cap on top of pump.
-Pour oil in from top.
-Your manual should tell you which oil to use. 10-20 or 10-30 non-detergent should do.
The engine.
Look for oil cap on lower side of engine
Use regular 10-W-30 motor oil.
Don't over-fill. About half way up dip stick is about right.
Never turn gasoline engine upside down to drain oil, or oil will flow into carburetor.
Oct 06, 2010 | Briggs & Stratton Garden
What oil, how much oil, and how change oil on pump of ry80030a
The RY80030 Pressure washer has a Faip pump on it. There is no drain plug and you do not change the oil in it. The pump only holds 4.5 ounces of oil and the pump only has a life expectancy of between 30 and 50 hours. If for some reason The oil gets drained, remove the pump from the motor and set it on a bench standing up on end. Remove the allen bolts holding the water and oil sides of the pump together.Be carful as the piston springs are under load. fill the pump 3/4 of the way full and replace the head. there is a smoke stack on the pump but it is simply a breather not an oil fill.
If this helps please rate this post. Bill the Tech
Dec 17, 2009 | Karcher 2500 PSI Pressure Washer
Change the Oil
the easiest way would be to purchase a manually pump up oil change device that draws a vacuum and you put the tube from that device in the oil fill hole and draw it out to its own container
May 25, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Transmission/clutch fluid
The engine oil also lubricates the transmission and clutch. There is no separate procedure for changing it, changing the engine oil is all there is.
May 24, 2009 | 2005 Honda CRF 450 R
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
Foaming in pump oil window
I dont know which comet pump you have, but it is just easier to get a new pump from one of the pressure washer companies on the internet and they sell them on ebay. You can also probably get a better pump that will fit your engine as well. Also, have you tried just changing the oil and not fill it too full? On my 5000 lb washer, if i fill the oil too high when I change the oil, it will foam some. Hope this helps you, Rick
Apr 27, 2009 | Northstar Pressure Washer 3000 PSI
Briggs & Stratton Prosumer 20324 Gas Pressure Washer Logo
609 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
