Home | Mitsubishi | WS-55809 55 in. Rear Projection Television | No picture and power shu...
Mitsubishi WS-55809 55 in. Rear Projection Television
Problem for Mitsubishi WS-55809 55 in. Rear Projection Television
No picture and power shuts off after 3 seconds
By mr_sparkyz on Jun 22, 2009
I have no picture. The lamps aren't even firing. I was getting a 12 code and now I am receiving a 23 code. I can get sound just no picture. Help!
Comments:
Jun 22, 2009
- Thanks for the reply, however, there is no evidence at all that there was any kind of leakage.
Jun 22, 2009
- You say that it would be obvious, what exactly would it look like? The only thing that I see that is obvious is some kind of "paste" around the lamp bases. It is there on all three so I'm kind of led to think that this is supposed too be there.
Jun 22, 2009
- It was running for about 5 minutes with a 12 code. Sound but no picture. Then it shut itself off and now I get a 23 code and it turns off in a second or two.
Jun 23, 2009
- Hi again, Model WS-55809, Serial #120316, and after reading some of the other postings, the picos were one of the first things I checked. No problems there, Three 5A's are good; one 10A is good; two 7A's are good. I have my multimeter set at 2000 ohms, would that be adequate?
Jun 23, 2009
- I'm an electrician by trade so I've dealt with fuses before, however, these picos are new to me. One thing I do see, a ton of dust!
Solution #1
posted on Jun 22, 2009
Not Helpful)
Skyassoc
Rank: Guru  Televisions & Videos  Expert
Rating: 90%, 253 votes
I would look to see if any of the CRT cooling fluid has leaked onto any of the circuit boards. You can do this pulling the front grill off the front of the unit, then remove he screws holding the wooden access cover. Then look carefully around the boards nearest the front of the set. it will be obvious if you see any. Bad news is that if you see any, put it out to pasture. The cost to repair would be more than replacement. Any of the boards that are found with that leakage on it must be replaced and all the CRT's should be replaced to make sure of no more leak problem or color imbalance due to new and old CRT's .
I hope this helps,
Skyassoc
Comments:
Jun 22, 2009
- It would look like clear droplets or a small pool of clear liquid on one or more of the three boards on the bottom.(Signal board, Power/Convergence Board, HV Board). In severe cases the area would be grayish or blacken due to the corrosion properties of the liquid. The paste areas you see are normal on the CRT Boards.
What is the model # and serial #. I may be able to get better info for you.
Jun 22, 2009
- If you are handy with a VOM , unplug the unit, take the back off and look at the center board(Power/Convergence board), carefully look for green pico fuses. these would be more on the left side of the of the board. They would look similarly to resistors. When measuring, they should all read 0 ohms. if any read high or open, what ever circuit the correspond to is faulty. If you don't feel confident in doing this, get a Auth. Serviceman to check it.
I hope I did'nt go overboard on this. Good luck.
SkyAssoc
Jun 23, 2009
- Dust does occur. TVs seen to just draw it in. The setting of your Multi Meter was fine. I'm getting a feeling that you may have a issue on the HV Deflection board. I will what I can find out with some other sources I have. I 'll get back to you as quickly as I can.
skyassoc
Jun 24, 2009
- I have found out that the first code you can ignore. The second code(23) is telling you that the Horizontal and or Vertical circuit has failed. It was suggested to me that the Yoke Connections be checked at the Yokes themselves. It is common for the solder connections to open up for the Horizontal part of the connector.
since it is wired in series from Yoke to Yoke, it only takes one of the connetores to open up to cause the problem.
If the connectors are not the the problem. You can order the Main Board (The Deflection HV Board) from Mitsubishi at 800-553-7278 with part # 930B866006. Retail cost of the part from them is 415.00.
Well this all I got for you,
I hope it helps you to getter go'en
Skyassoc
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Mitsubishi WS-55809 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55809 55 in.
Do you recommend Mitsubishi WS-55809 55 in. Rear Projection Television?
Answer
Answer
i have an older projection tv and the red yellow and blue dots are showing through.projection dots i... (More)
Answer
the TV will not turn on and the green light just blinks. The directions say to push the reset button... (More)
Answer
Mitsubishi W555809 TV won't start. Had a play station 2 hooked up for a couple of weeks and once... (More)
Answer
My dad's tv has sound but no picture mitsubishi television (model wd52528). BUT he messed with the... (More)
Answer
how do i remove and install the motherboard in my mitsu WS 55809 tv. thanks
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-55809 55 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
