Question about Frigidaire GLTF2940ES Front Load Washer
Fridgidaire Gallery Series Front Load washer won't drain or spin
Suddenly, there was a klunk sound when the drum turned. It did the slow spin back and forth and then spun fast but the water didn't not empty. Could it be a clogged drain or a broken strut?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
It sounds like there may be 2 things wrong. If the drier is not draining then the pump is clogged. Remove the drain hoses and check the pump(IMPORTANT!!!!Before you remove the hoses get a pan to put under the hoses. Alot of water will go on the if you do not do this...)The pump most likely has a coin in it.
The klunk you heard... If the drum spins and seems to be out of balance. If could be your rear bearing or your spider bracket.
Posted on Jun 25, 2009
Fridgidaire gallery front load washer doesnt spin out and leaves clothes wet
sounds like the belt that goes around the drum has come off the pulley or belt has broken you should be able to look under it to see the belt is on or off. hope this helps you.
Dec 13, 2010 | Frigidaire GLTR1670A Front Load Washer
Water will not drain and washer will not spin
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 01, 2010 | Frigidaire Gallery Supreme Series...
I have a KENMORE WASHER MODEL 11020894990.The slow spin comes on and works fine but when it stops to begin the faster spin it makes a klunk klunk noise and will not spin.
Well the klunk-klunk is the Break grabbing, to stop it, as it is detecting, what it thinks, is some sort of Unbalance or Overload, or detecting a motor fault, etc, real or not, and is shutting itself down because of this.
Feb 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
285 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
