error window comes up and says it is checking for a solution for about 5 seconds and then goes to a window that says it will close the window and windows will notify me if there is a solution. You then must manually close the window or it will stay running. It is Office 2003 and is on a vista home premium machine. I have put the disk in and reloaded it also tried to repair and it says it was successful but no luck.
download ccleaner from ccleaner.com .
1. Remove office.
2. Run ccleaner and remove temporary files
3. Run ccleaner registry. Second Icon from the top.
4. Press scan for issues. when it will complete. Fix selected issues will be highlighted.
5. Restart the computer.
6. Install office.
If your problem is solved kindly rate the solution.
thanks
Was this helpful?
Yes
No
Popular Solutions for Microsoft Office Outlook 2003
I want to convert amipro document which has equations and diagrams to word file. I tried three or...
(More)
I want to convert amipro document which has equations and diagrams to word file. I tried three or four converters but the text is getting converted, the equarions and diagrams are missing. Kindly help me in this regard.
my outlook 2003 does not allow me to use the cursor on selecting text on word. how can i fix it, i...
(More)
my outlook 2003 does not allow me to use the cursor on selecting text on word. how can i fix it, i have repaired office and did system restore it still fails. office word is working fine
I am attempting to edit a shared calendar in Microsoft Office Outlook 2003. But it is giving me...
(More)
I am attempting to edit a shared calendar in Microsoft Office Outlook 2003. But it is giving me "unable to display the folder. The server mailbox cannot be opened because the address book entry is not a mail user." What does that mean and how can I fix it? I am running Windows XP Professional SP3.
The user made extensive updates to a Word 2k3 document he received and did a File-Save As. The...
(More)
The user made extensive updates to a Word 2k3 document he received and did a File-Save As. The document 'saved' without any problems. More changes were made , the file saved and Word exited. Later in the day the user went to open the document and could not locate it anywhere (it was not even listed on the Recent) list. For 2 hrs. the user searched the local drive, temp folder, network folders...the file was not there. (The searches were by file name, words in the document, the date.). The user said that the problem only occurred once. I stepped him through creating a new normal.dot after learning that he had been having a recurring problem with the normal.dot. Will this resolve his problem or should other measures be taken? And what did Save As do with the document? Thanks...EJohnson/HDT
