Question about Dell 4100MP Multimedia Projector
Dell 4100 MP Won't turn on
I was using the projector for about 30 minutes and it shut off. We let things cool off but never would turn on again. We also tried another plug, different location and also replaced the bulb.
The projector only has about 5 hours on it
SOURCE: Dell 2200MP projector
We have had two and they both did the same thing. We sent the first one back because it was still under warrenty, they sent us another one, it does the same thing.
Posted on Aug 15, 2008
SOURCE: dell 4100 mp projector
Hold down the Fn key and press F8 at the same time. This should do the trick.
Posted on Apr 06, 2009
SOURCE: Dell 2300 MP temp light flashes and projector turns off.
I am experiencing a similar problem with mine. It will cycle on and off without actually powering up fully and then after about the 4th or 5th time it will shut off completely and the lamp indicator light on top illuminates. i am reading in other blogs that this is a design flaw on this unit. let me know if you have found any fixes.
Posted on Feb 08, 2010
SOURCE: dell 4100mp bulb wire
The bad new is you can't / the" lampwires" ARE the very sohpisticatedl amp. You have to buy a new lamp
Posted on Apr 29, 2010
lbrown1806
  • 488 Answers
SOURCE: Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Posted on Oct 23, 2011
Why does my Dell 1510X Projector not shut off when I push the off button ?
This projector as with most high power projectors will have a cool down period for the lamp once the power button is pushed from on to off. For this model, the cool down period is 120 seconds after which the unit will fully power down. You can override this cool down period by pushing and holding the power button for 1 seconds. If you use this procedure though, you should not power up the projector again for at least 60 seconds to allow the internal temperatures to stabilize.
Feb 27, 2015 | Dell 1510X Projector Projector
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
Oct 23, 2011 | Dell 1209S DLP Projector
Dell 3200MP projector. Lamp warning light comes on after approx 30 minutes of use and the lamp turns off. Bulb is new. I am not sure what the warning light is indicating.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 18, 2010 | Dell 3200MP Multimedia Projector
Jan 31, 2010 | Dell 2300MP Multimedia Projector
Dell 4100mp bulb wire
Dec 05, 2009 | Dell 4100MP Multimedia Projector
Dell 4100mp shuts down
It sounds like the fan in you 4100 is defective.
Jul 14, 2009 | Dell 4100MP Multimedia Projector
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
Dell 4100 mp projector
Mar 12, 2009 | Dell 4100MP Multimedia Projector
Dell 4100MP Multimedia Projector Logo
213 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
