Question about Maytag 24 in. MDB7650AWS Built-in Dishwasher
Maytag MDB6650AWW will not fill
Water source is OK.
I changed the inlet valve and the float switch and cleaned out the float.
Still will not fill.
Any ideas ?
My Maytag MDB6650AWW dishwasher would not fill. The lights on the panel were on when I tried the wash cycle. I tested the water valve but no voltage was found during the cycle. I thought it may be the timer/control circuit. I traced the power from the door switch and found no power going to the float switch leg. I found two wires completely cut through (one going to the Water Valve) and three others partially sliced.
Posted on Dec 13, 2008
  • John Young
    John Young Jun 02, 2012
    My MDB6650AWW had no power at all. I found that where the wires come out of the door and turn to go under the wash tub many wires were cut from a sharp edge and the door being opened and closed many many times during its use. Using wire of the same size I cut each broken wire out of the wiring harness and replaced it. Then I put some plastic spiral wrap around all of the wires and taped it good. Its been working since then. There arent many parts in a dishwasher that can go bad so its ususally pretty easy to eliminate the culprit. One parts manufacturer even lets you buy parts, try them and return the ones that don't fix the problem. repairclinic.com return any part within 365 days.
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
No water in dishwasher
I would suggest to check the information by clicking here if you are planning to DIY.
May 20, 2008 | Dishwashers
Water will not fill the dishwasher, it runs but it will not fill with water...is the water inlet plugged?
Hello there
The most common causes of this problem are a defective water inlet valve or a stuck float switch. The float switch sits under the dish racks and sends a shut-off signal to the dishwasher when the water level is high enough. Make sure you only use a Maytag-compatible replacement if you have to change out your dishwasher's float switch or water inlet valve.
Difficulty: Moderate Instructions Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Scrub brush
  • Replacement parts (if necessary)
hd_clickable2_area.gifGet what you need for every
project at HomeDepot.com
  1. 1 Shut off power to the dishwasher from the home's circuit breaker box. Remove the lower rack from the inside of the dishwasher.
  2. 2 Check the water inlet valve to see if it clogged or broken. Replace the valve if you notice any problems and test the dishwasher again. If it still does not fill, proceed to Step Three to troubleshoot the float switch.
  3. 3 Consult your owner's manual to find the location of the float assembly. Remove the cover, if applicable to your dishwasher. There may be retaining screws holding the cover in place or it may just snap off.
  4. 4 Hold both sides of the float while you raise and lower it several times. The float should move freely without binding or catching on anything. Disconnect and use a scrub brush to clean the float if you feel any resistance.
  5. 5 Reattach the float and test its movement again. If it is still not moving properly, replace the float.
  6. 6 Replace the lower rack of the dishwasher and turn the breaker switch back on.
Read more: How to Troubleshoot a Maytag Dishwasher That Does Not Fill ' eHow.com http://www.ehow.com/how_6284004_troubleshoot-maytag-dishwasher-not-fill.html#ixzz1A891ccai
Jan 05, 2011 | Maytag MDB6769AW Builtin Dishwasher
The dishwasher goes through the cycles but will not fill with water on some cycles.
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter hen you'll need to replace the water inlet valve assembly.
Please post back for any further assistance.
Daniel
Oct 20, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Dishwasher - MDB6650AWW wont fill after initial fill
sounds like a bad module control. let me know if this helps with a 4 thumbs up post
Feb 27, 2010 | Dishwashers
Dishwasher tub will not fill with water
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
May 24, 2009 | Dishwashers
Dishwaher will not fill
is the float switch stuck in the up position?either soap built up or some other object may be stuck under it.
Nov 03, 2008 | Dishwashers
I have a Maytag dishwasher model DWU8860 and it doesn't always fill after a pumpout cycle
It is probably a faulty inlet valve. Check the float switch first.
See here how to locate the parts.
See also this advice for repairclininc:
" There's no water entering the machine If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Sep 06, 2008 | Maytag Dishwashers
Magtag MDB6650aww dishwasher will not fill
remove the lower kick panel inside the washer is a float that goes through the bottom of the tub look under the washer and make sure the end of the safety float rod is on top of the safety float micro switch if its not it wont fill if that don't do it let me know we will trouble shoot the rest but that is probably it
May 24, 2008 | Maytag 24 in. MDB7650AWS Built-in...
Maytag 24 in. MDB7650AWS Built-in Dishwasher Logo
412 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
