Question about HP Officejet 5610 All-In-One InkJet Printer
My All-In-One Printer is plugged in,but it won't scan,fax,or prin
Well,we plugged in the All-In-One,and for a couple months it worked,but then it just stopped working.I tried going to settings and making it so it would be ready for printing,and scanning and all that jazz,but it still said that there was no printer connected to the computer.I have a laptop,and I even tried blowing into the USB thing to see if any dust was in there.It didn't work all that well in the first place,but it just stopped working now.It turns on,and you can press the buttons and stuff,but it just doesn't scan,fax,or print.
  • sonic3696 Jun 22, 2009
    No no no,I can press the buttons,the printer turns on and the buttons can be pressed and I'll get a response.But no,overall the entire thing doesn't work. :( Which means the printing,faxing,scanning.
  • mnguy7764 May 11, 2010
    So you are saying it will scan if you push the buttons, but if you try it from the computer it says there is no printer? I think perhaps you have a bad USB cable, do you have a friend that you could use their cable as a test?
SOURCE: Printer will copy and scan but will not print anything from internet
copi driver instal to my computer
Posted on Oct 02, 2008
  • 44 Answers
SOURCE: ''clicking'' noise started randomly- cant use printer
Hi starrz54,
Here is the HP site that talks about resolving unexpected noises (such as clicking)...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu06191&lc=en&dlc=en&cc=us&lang=en&rule=26695&product=303753
You also might try doing a full reset on the device. Here is how to do that: While switching on the scanner press # and 9 to initialize.
I
This should give you some good directions and if it does not resolve the issue, the next step would be to have it serviced or replaced.
Posted on Nov 16, 2008
SOURCE: Can't scan on HP Photosmart C4380 even tho printing works fine
I am sick and tired of the problems i have with this PSC, but i have found a scanning solution and thought i would share it.
Use Microsoft Paint. It's not the best application in the world, but you can insert a scan from a scanner in the 'file' menu. :0) The scans are not of the best quality, but i'm grateful i can scan at all with this useless PSC.
Posted on Apr 18, 2009
  • 72 Answers
SOURCE: I have a hp 2410 and get only blinking green light and hour glass
unplug the power cord from back of printer and than press and hold the ON button for 30 second, than release the button than connect the power cord and turn on the printer
Posted on Aug 09, 2009
SOURCE: Printer and copier work fine- scanner says USB not connected.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
Posted on Sep 21, 2009
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
When Printing Of the internet script error comes up and printer will not prin
which web browser are you attempting to print from? and is this through a windows pc or is it on a different os?
Jul 30, 2013 | Samsung Clx-4195Fn 4-In-1 Colour...
The top left "hinge" won't seat, therefore the top feed can't be used to fax, scan or copy.
It's possible that the hinge of the scanner cover broke. If that's the case, you won't be able to scan from the ADF (Auto Document Feeder). If the printer is still under warranty, please call our technical support team to have the printer replaced.
Aug 10, 2012 | Lexmark Pinnacle Pro901 Inkjet Wireless...
My lexmark x7170 all in one won't copy or scan starts to but stops
It could be a scanner hardware problem. Try to unplug the printer from the power source to reset it. Wait at least 10 seconds and then re-plug the printer back into the power. If problem continues, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Jun 29, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Cannot scan using Mac OS to HP B110 error message failed to open a session on the device....printer all ok
This is the same thing as one of my friends pinter that i fixed earlier.
try this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00274694&cc=us&lc=en&dlc=en&product=1153494&tmp_track_link=ot_search#N162
This document will provide you a step by step solution to fix your issue.
The good thing about this is that it also provides full illustrations
Send us a feedback if it works.
Mar 04, 2011 | HP Photosmart C6180 All-In-One InkJet...
Scanner failure error code
You can try a reset on the printer using the # and the number 6,holding them down
while plugging in the power cord at the back of the printer.if it still does not work
then you can try the same with the # and the number 9.If it still does not work,get
your printer serviced.
Jan 06, 2009 | HP Photosmart C7280 Printer
Lexmark x7350 will not scan, fax or copy
If under warranty contact mfg for warranty repair locations
Sep 09, 2017 | Lexmark X6170 All-In-One InkJet Printer
Trouble faxing and scanning
If you havent already tried this, I would completely un-install all of the lexmark software, go to the lexmark web site, dowload all the latest software for the printer and re-install and see if that corrects the issue first.
hope this helps,
printdoctor
Sep 26, 2008 | Lexmark X8350 All-In-One InkJet Printer
Printer keeps restarting itself all the time, and does not print at all
Try downloading the latest firmware. Ti might sort it out for you.
Jan 30, 2007 | Brother MFC-5440 Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
232 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
