Press the " " button until the CACL CLEAN symbol appears. Press the " " button to start the descaling.
The machine reminds you to insert the carafe and pull out the what is in there dispenser. The descaler symbol appears on the display. ...
Take out the water tank. Pour the entire bottle of Saeco descaling solution in the water tank.
Top up the water tank with fresh tap water to the MAX line. (Please ensure the max line is reached otherwise this will require further rinsing). Place the water tank back into the machine. ..
Place a bowl underneath the milk carafe dispenser and the dispensing spout.
Pull out the milk carafe dispenser to the right up to the " " icon.
Press the " " button to start the descaling cycle.
The machine will start dispensing the descaling solution at intervals. The bar on the display shows the progress. This takes about no moro then 25 minutes.
from the menu select descaling and open the steam knob. The machine is doing descaling.When descaling proces finish fill the water tank with frsh water and rinse from the hot water .When water finish you are ready to drink coffee.
Descaling Saeco Automatic espresso machinesSAECO VIENNA SUPERAUTOMATIC MACHINES: SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM 1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.) 2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes. 4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand. 5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared. SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM 1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle). 2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear. 4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water. 5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared. Descaling Single Boiler Home espresso machines(HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent. 1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results). 2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution. 3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes. 4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes. Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through. 5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty! 6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Use Scalekleen or other citric acid.
1- Always use the right descaling products.
Descaling chemicals purchased from supermarkets may not be suitable for the
machine. Use of Vinegar is prohibited by manufacturers. Please read the
operating manual. Do not use Cafiza, Cleancaf or PuroCaff. These are coffee
cleaners recommended for back flushing coffee machines.
2- Always dissolve the Descaling chemical in a container and pour into the water
tank. Never add directly into the water tank. Crystals of chemical will slide into
the filter & pump and block the water hose and restrict flow of water.
3- Do not pour solution when the tank it is on the machine. In fully automatic
machines, the bean hopper is next to the water tank. The solution / water can
accidentally get into the bean hopper and cause serious damage to the grinder.
4- Espresso machines have separate water passage for Hot water from steam
pipe and espresso dispensing. Flush the solution from both sides, alternatively.
Turn machine on, flush one cup from steam pipe and turn machine off. After a
pause of 3 to 5 minutes turn machine on and make one large espresso (4-oz.).
Repeat this process until all of the solution in the tank is used up.
This method is best both for semi-automatic & fully automatic espresso
machines.
Using Electronic programmed method does only half the job as it flushes
descaling solution only through the steam pipe. The machine must be flushed
with solution from espresso side as well. Automatic descaling method should be
completed by making 6 espresso with or without coffee (using pre-ground cycle
when available).
5- Rinse the water tank and fill with fresh clean water. Repeat the rinsing process
alternatively until four tanks of water is used up to flush the chemical out.
Caution: Do not leave the machine before completing the rinsing
with clean water. The solution left inside will corrode & tarnish
metallic surface.
Do not leave Chrome plated objects submerged in descaling
solution for more than 10 seconds. The chrome will dissolve and
leave the item permanently corroded and black.
Buy an espresso machine descaling agent (they come in packets, and you can get them all over the internet), and follow the instructions that come with it. Do NOT use vinegar like you might use on a drip machine.
Ok first check if the machine is in greenlight state when you press and hold the water button, as it will not work when the red exclamation mark blinking.
also check if the button work at all flipping back and forth to hot water and steam.
I have never had this problem that it dident work.
But remember this, you dont have to do the descaling again as that has nothing to do with the reset.
You can even reset the descaling alarm with out having done the descaling.
If that for some reason wouldent work I would think its the CPU card is not working.
you didnt use the machine for a long time start the machine remove the water container if you have a turker blaster fill with water the hole were the water container goes put the blaster in it and apply pressure and try to ventilate and for descaling the machine use descaler not vinergar. vinegar remove calcium in little piece descaler melt it use 1 part descaling produit 1 part water put that in water container start machine open valve turn it off after a few second let it rest for 15 minute and repeat untill empty do 2 or 3 rinse cycle with clean water it important that stuff is corosif thanks for using fixya pierre
