Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Replacement of motherboard
We had a fix it guy come in to look at the fridge he "determined" we need to replace the motherboard, he didnt add any details, im going out to purchase the part today but how do i install it back there are onbly bout 6 conections but one looks like it wasnt conected in the first place, maybe you cn help me. GE Model No. gsh25jsrfss Serial No. vh212771
  • bb_morris Jun 26, 2008
    I have the same problem with my ge side by side ice maker. It makes ice but won't dispense it through the door. I have been researching and I think the motherboard may be my problem too. Should I replace it?
  • mamusillami Nov 11, 2008
    I have the same problem. Want to order the correct part; but am not sure of the part number. My Model# GSH25JSRF SS Serial # FH251513
  • 770 Answers
Call me i will walk you thru it 345-916-2343 too much to type here
Posted on Jan 26, 2008
I have a ge side by side dss25kgrd ww fridge. The freezer is freezing up an the fridge side is freezing the second draw. I had a service guy come an test the heater at the bottom in freezer.And said it ...
replace or first test the thermistors in both the freezer walls and refrigerator sidewall behind little plastic grilles ,they are easily tested by temp/voltage and are only $10.00 a piece,where as the motherboard is over$100.00
Mar 03, 2011 | Refrigerators
My fridge/freezer is not cooling. I had a service
The reason that the service guy to you to just toss the unit, is probably due to the fact that repair or replacement of certain system components might end up costing more than just replacing the unit. If there is a refrigerant leak for instance. The time needed to try to find the leak, might end up costing you $500, then depending if the leak could even be found, it would then need to be fixed, probably for around $100. Now you are into an older fridge for $600, and hopefully all goes well from there. On the other hand if after searching for a leak for several hours, and not being able to find it, which does happen, are you still going to want to pay the $500, and still not have a working fridge? This is the reason a guy might have "simply" said "toss it". If on the other hand, you don't think the tech even looked at the unit, then I would suggest having a reputable company take a look at it. Hope this helps
May 05, 2010 | Admiral 26 cu. ft. Side-By-Side...
Fridge short circuits power after a period of time
it needs a new defrost heater , can b a bit tricky to change
Jan 31, 2010 | Refrigerators
Replaced start relay, still didnt help :(
It sounds like the Tech only did half his job and seen that the start device was burned up and called it that and didnt check the compressor or you got a bad start device or, you didnt put it on corectly or the thermostat in the refrigferator is off.
When you put the new start device on and you pluged the machine on, Did the condensor fan come on (the fan right by the commpressor ??)
If that fan came on and the compressor did not start.
the windings in the compressor could be bad and you will need a compressor for that machine.
Oct 08, 2009 | Maytag MSD2352KES Stainless Steel Side by...
Kenmore Cold spot 106 Warm Fridge
I would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Power supply regulator for rca 52" home theatre twin tuner pip
no parts from a pioneer wont work. There are roughly 4 regulators for the power supply maybe 5. The sad thing is they cost between 7 and 20.00 , he didnt happen to mention which power supply was affected did he? You would have to check the various regulators out of circuit to determine which one is bad. If its a F.E.T they are hard to check without the proper equipment.
Apr 05, 2008 | Televison & Video
CPU Problem
Most likely it's the motherboard but to make sure. Ask your maintenance guy to plug in your CPU to a working motherboard... If your CPU fails, change it. Same with the board. Put the working CPU on your board. If the board fails, change the board.
Feb 29, 2008 | ASUS P4VP-MX Motherboard
Dell Inspiron 2200, power input broke on motherboard
HEY ALL THE PART NUMBER IS (PJ016) And here is where you can get it: http://www.parts-people.com/index.php?action=item&id=4109
Feb 28, 2008 | Dell (8N816) Motherboard
Door Handle
If you enter the make and model no. then people may be able to direct you to a suitable website. Alternatively enter your make of cabinet and add freezer spares and Google search it. Hope this is of some help.
Sep 09, 2007 | Samsung RS2630SH Side by Side Refrigerator
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
1,367 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
