Question about Bose Companion 2 Computer Speakers
How do i hook up speakers to my lcd?
Trying to hook up speakers to tv. speakers only came with a mini-plug audio input cable
  • arbelaezml Jun 22, 2009
    could i discard the mini plug audio input cable and just buy an rca audio connector. red/white
    Problem Solver:
  • 5 Answers
Go to Radio Shack or whoever is closest for audio cables, ask for a mini-stereo jack to RCA male jack, it should look like a Y with the stereo mini female jack on one end and two (one red one black or white) old style speaker jacks. These should take care of the audio situation. It might be better to consider adding a tuner or media center to help direct the sound.
Posted on Jun 22, 2009
  • Mark Shepard Jun 22, 2009
    If the speakers have RCA connectors in the back then yes, otherwise you will need the convertor.
Sound
Your TV has a pair of analog RCA Audio Outputs on the back of the set. They are the red and white, female, round outputs and should be labelled as Audio Out. If you have a surround receiver or stereo that accepts this type of input (most do), then you would purchase a stereo RCA audio cable that has the red and white male ends on both ends of the cable and plug them in to the appropriate stereo RCA left and right channel audio inputs on your receiver and the aforementioned outputs on your TV. The same is true if you have a pair of self-powered computer speakers (or similar). If your external speakers or audio systems don't have the RCA inputs, you may need to get an adapter to convert the RCA output to stereo mini-jack (or similar) to match the appropriate input on your external speakers. Does that make sense?
Apr 14, 2014 | Sceptre X322BV HD 32 inch Class Television...
How do i hook up a rca Rtd325w dvd home theater to a coby tft lcd flatscreen
You can use either the multi pin connector cable, or plug the white, yellow and red cables to the TV set at the DVD player input or "Video 1" and the the audio output of the TV Another red and white set of RCA cables into the audio input of the home theater. This way the TV can play through the home theater system when you are watching cable or over the air.
If you do not want to hear the TV audio, you should go to the audio properties and select "external speaker system" but if you do this the home theater system must be on to hear any audio from the set until you set it back to the TV speakers through the TV's setup menus again.
Apr 03, 2012 | RCA Audio Players & Recorders
Cant figure out how to hook them up
Two audio input cables are supplied with the speakers. If your computer has a stereo mini jack, use the cable with a stereo mini plug. Otherwise, use the cable with RCA plugs on both ends. Match the colors on the connectors to the colors on the jacks, red to red and white to white.
The speaker cable is already attached at one end to the accessory speaker. Plug the other end into the TO ACCESSORY SPEAKER jack on the powered speaker.
1. Connect one end of the audio input cable to AUDIO INPUTS A. 2. Connect the other end to your computer's AUDIO OUTPUT jack. We recommend using LINE OUT if your computer sound card offers more than one option. 3. To connect a separate CD-ROM, or another source, repeat steps 1 and 2 using AUDIO INPUTS B.
You must connect the AC power pack to operate the speakers. 1. Plug its cable end into the power jack on the powered speaker. 2. Plug the power pack blades into the wall outlet. 3. Turn on your computer sound source or external sound source.
Jun 27, 2011 | Bose MediaMate Computer Speakers
Can't get TV sound hooked up through sterio?
Hi ,
have you tried using a HDMI cable to hookup to your stereo?
that would be a better option.
george.
May 25, 2011 | Samsung 46 in. Flat-Panel LCD HDTV
I have a Samsung P2771hd monitor. I have green and black cords (for sound and microphone) coming from the computer. I bought a cable that has the black plug from the pc that splits to the red and white...
The Red (right channel) nand White (left channel) RCA plug to miniphone jack is made for audio amplifier with RCA input jacks. The monitor should have Green audio input mini stereo phone jack for the audio input from the PC audio line out (Green mini phone jack).
You will need the shielded audio cable with mini stereo phone plug at both end for the audio hook up.
Dec 21, 2010 | Samsung P2270HD 22" LCD Monitor
I can watch a movie from my computer to tv but the sound only came from the computer not on the tv
if you want the sound from tv, get an audio cable and put one end to computer where the speakers connected and the other to the audio input or aux in back of tv.
good luck hope it works, if so do rate the solution
Nov 28, 2010 | Vizio 42 in. LCD TV
Trying to hook laptop to lg lcd tv with s-video cable tv says no signal
Most laptops come with a VGA output terminal.And it depends if your LG LCD TV has VGA video input(it should be similar with your laptops' terminal).So if yours is equiped with that(VGA video input)It is indicated by The word or acronym "PC"input,and use a VGA cord available from Staples,best buy or your local computer shop.Also include an Audio RCA plug(Red and White) with an stereo earphone plug on the other end or else you'll have no sound.The RCA plugs goes to the audio input in your TV the other end goes to the speaker phone jack of your Laptop.
Oct 31, 2010 | Televison & Video
I want to connect 2 speakers(left and right) to lcd.how can i?
Please follow the steps below:
Step 1: Connect the two RCA plugs on the Y adapter to the right and left Audio Out jacks on the back of the LCD TV.
Step 2: Insert the mini-plug on the cable attached to the right-channel PC speaker into the mini-plug jack on the Y adapter.
Step 3:Connect the mini-plug on the audio cable attached to the left-channel PC speaker to the mini-plug jack on the back of the right-channel speaker. This completes the PC speaker connections to each other and to the television. The TV sends an audio signal to the right PC speaker, which separates the signal and sends the left-channel stereo information to the other PC speaker.
Step 4:Connect the AC power plug to the back of the right-channel speaker and plug the other end into an electrical outlet.
Step 5:Switch on the speakers and the television to enjoy audio from both the TV's built-in speakers and the external pair of PC speakers.
Regards
BEADHZ
Dec 30, 2009 | LG 37LC7D 37 in. LCD HDTV
Monitor audio hook-up
You should need a mini jack audio cable. One end plugs into the speaker port of your sound card in the back of the computer (usually marked green). The other end should plug into the audio input of the monitor.
Oct 06, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Vga audio in
VGA does not provide sound, only video signal.
to get sound, you need to run a signal from the audio output of the computer (1/8" mini) to the audio in of the TV (RCA).
Sep 06, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Bose Companion 2 Computer Speakers Logo
552 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
