Question about HP Officejet J4680 InkJet Printer
Need power cord for j3860 and instruction sheet
    Guru:
  • 224 Answers
Its not available anywhere,
How old is this printer if its more than 5 years old then it would be almost impossible to get the power cable of this printer unless you get it from a self made hardware dealer,
apart from that you wont be able to get the power cable I have specially called up hp and called up a couple more hardware shops trying to find the cable for you but it seems it is not available.
But heres a recommendation
call in to hp at 1800-474-6836 and simply ask for an upgrade,
Since you have an hp printer you will get a 50% discount on the upgraded printer
The upgraded printer comes with a one year software and hardware support,
meaning if you have a software issue hp will fix it and if it is a hardware issue then hp will replace the printer free of cost.
plus on this upgrade printer you get a universal power cable which works with most recently released printers so it make it easy for you to buy another power cable.
You can even extend the warranty on the upgrade printer for upto 3 years where you will get total support and if your printer goes obsolete then hp will replace it with a new printer free of cost.
This is one option I dont think there is any other option,so sorry
Posted on Jun 22, 2009
Where can I get a replacement power cord for my Lexmark printer.
Hi
Looking at the setup and spec sheets, the power supply is built in therefore no separate power block (transformer) to worry about. The power cord on the set up sheet looks to be a "Figure 8". Check on the printer itself and if the socket looks like this:
then it almost certainly a standard lead that is used for many electrical appliances as well as computer peripherals, and should be obtainable at most electrical or computer shops. If you ask for a Figure 8 mains cable they should know what you mean but if have a way to take this picture with you - even better !
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 17, 2014 | Lexmark S815 Genesis AllInOne InkJet...
I haveHP 6110 all-in-one printer that I can make copies from my lab top computer by...clicking on print...connects to printer.....says paper jam...I then press "enter" on the printer....a sheet of pap
You may try to reset the printer per HP instructions.
1. Turn on printer with power button
2. With printer on, disconnect power cord from rear off printer.
3. Unplug power cord from outlet
4. Wait at least 15 seconds
5. Plug the power back into the outlet
6. Reconnect power cord to the rear of the printer
7. If printer does not come on, press the Power button.
Dec 30, 2013 | HP OfficeJet 6110 All-In-One InkJet...
I have an error message 982
In most cases you will get this type of error when additional trays are installed.
If you have installed the 2000 - sheet option, try uninstall it from the printer. If this will clear the error then the small controller board on the sheet option needs replacement. Also, check the power cord of internal power card on the 2000 sheet option tray if its properly inserted.
If you don't have the option sheet installed, try removing the trays and verify which one caused the error. If you still get the same error, a replacement of the printers' controller board is needed.
May 08, 2012 | Lexmark T632 Laser Printer
We were given a HOT POINT Heavy Duty Dryer with Automatic Dry Control, Model DLB2650BRLWH, Serial No. DG241274H and had to buy the power cord to go with it. Ordered the cord from a local appliance company,...
Technical explanation: Older 240 Volt appliances use a three-wire power cord (Black, White, Red). The White wire is the "neutral" connection, which is tied to Ground at the service entrance panel. The Black and Red wires are opposite phases of the 240 VAC (when one goes positive, the other goes negative). The neutral wire is "in between", so measuring the voltage between the black or red wire and neutral would give you 120 VAC. The green wire is frame ground; the electrical code requires newer (since 2008) 240 VAC appliances to have a separate ground bonding connection to the frame; the neutral connection is not considered adequate protection for certain failure conditions.
Look for a screw head or terminal stud on the frame or sheet metal of the dryer labeled "Ground", "Earth", or one of the following ground symbols:
The green wire goes to this point. DO NOT connect the green wire to any of the wiring inside the dryer, unless it is a green wire attached to sheet metal or a bracket!
The black, white and red wires go to black, white and red terminals you already found.
Mar 17, 2011 | Hotpoint Dryers
C4200 printer is woking only at a very slow rate that is to say prints two inches at a time instead of printing a full sheet
For products with keypads on the control panel:
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6′ keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
For Box-type models:
1. Unplug the power cord from the printer.
2. Wait for 30 seconds.
3. Plug the power cable back in the printer and turn it on.
Nov 21, 2009 | HP Photosmart C4250 Multifunction Photo...
No usb cord in box
this is straight from canon.com
dot.gif PIXMA MP970 All-In-One Printer dot.gif Power Cord dot.gif Print Head dot.gif Ink Tanks:
PGI-5 Black
CLI-8 (Black/Cyan/Magenta/Yellow/Photo Cyan/Photo Magenta) dot.gif Document Kit: Cross Sell Sheet
Easy Setup Instructions
Network Setup Guide
Quick Start Guide
Setup Software & User's Guide CD-ROM so it looks like you'll have to purchase a usb cord.
Mark
Apr 30, 2009 | Canon MP970 Photo All-In-One InkJet...
Need to forward a cal to an outline phone number using Partner 18
YOU CAN DIAL A CODE ON ANY PHONE *72 AND THEN FOLLOW THE INSTRUCTIONS THAT FOLLOWS
Mar 31, 2009 | Avaya Corded Phone avaparp18d
L8341 digital camera, Ido not have a manual, a disk, or a cord?
i can solve the manual problem but not the cord here is a link to the manuel
title_instructs.gif spacer.gif Click on a link below to view the Adobe PDF Format Instruction Sheet. To ensure proper operation, please download ALL instruction sheets for your product. spacer.gif spacer.gificon_acrobat.gifspacer.gif L8341: Kid-Tough™ Digital Camera
Mar 28, 2009 | Fisher Price Fisher-Price L8341 Digital...
Instruction sheet on setting up phone
what do you mean area codes are auto matic and puting in numbers the phone should have stored them in memmory what else are you trying program into this phone
May 10, 2008 | GE 29195GE2 Corded Phone
HP Officejet J4680 InkJet Printer Logo
147 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
