Question about Cycling
Wont start at all
Just bought a 47cc mini bike never had gas in it.
First day we out gas in and it starts up but sounded like it could die any moment. Also we couldnt ride it cause tire was flat.
So the next day we blow up the tire and now it wont start and is leaking gas like crazy. its electric start and its not the battery or the spark plugs. any help? or do i have a bike thats ready for the garbage
  • 174 Answers
Find out where the leaking gas is coming from. It has to go from the gas tank to the carb. Just follow the line. It may just be a hose is off or split or a gasket in the carb needs replacing. Not garbage. Anything can be fixed cheaper than buying a new one
Posted on Jun 22, 2009
I have a pocket bike that wont start unless u put gas where the spark plug is and then it will run&idle but once u give it throttle it dies there is no high or low screw there 1 screw &the idle screw
Hi, Anonymous more than likely it's clogged carburetor jets, obstruction in the fuel system or a faulty battery for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Common Reasons Why My Pocket Bike Wont Start
Pocket Bike Won Start Help Quick Fix
What To Do If Your Pocket Bike Won Start or any 2 stroke engine
Pocket Bike Not Starting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 01, 2016 | Motorcycles
How do I fix my 49cc 2 stroke pocket quad it has
If you have replaced the spark plug then the possibilities are the ignition coil is weak or the starter mechanism is faulty.
See this site for details of parts.
Mini Atv Quad Parts 47cc 49cc Stock Replacement
Sep 15, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
Tried to adjust the fule screw and drop the idel but still runs high and dies when i hit the gas
CHECK OUT YOU'R CARBURETOR MAYBE THE FLOW OF GAS MAY NOT BE DISTRIBUTING RIGHT,YOU MIGHT NEED
TO REBUILD IT.YOU TRY,D EVERY THING ELSE. BUT THE CARBURETOR,TRY CARBURETOR CLEANER IT COMES IN A CAN SPRAY YOU COULD GO TO AUTO ZONE, MAKE SURE YOU FOLLOW DIRECTIONS.
D,R, CLAUDIO
Dec 19, 2017 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
DOES NOT WANT TO START
It needs fuel, air and spark to run check each system to see which one you do not have then trouble shoot that system.
May 27, 2010 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
I havent started my baja mini bike since last fall and now it wont start it seems to be not getting any gas
Chances are the carb is plugged up with stale gas. The carb will need to be disassembled and thoroughly cleaned, including all passages.
May 20, 2010 | Mini Motorized Bike
I have a 47cc pocket rocket and there is no spark at all.
first, if all connections are good, try replacing the spark plug, if still no good, check if coil gap to rotor is .020". if the is good, you will need to replace the ignition coil.
Oct 17, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
What size/type of spark plug is in the 47cc mini pocket rocket
Check the owners manual, a lot of pocket bikes have different size spark plugs.
Jul 15, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
My 50cc mini bike starts then dies 5 secs after starting. why?
It sounds like you may have 2 problems
  • Bad gas
  • dpossible loose spark plug( bad compression)
Solution
dump out the gas put new in
Remove the spar plug and examine the plug if it is wet and black it is fouled
if it is white ad dry it is not getting gas
If you can replace the spark plug if not just clean it with a wire brush put back in and tighten
Finally make sure the spark plug wire is not lose
Best of luck to you
Jan 01, 2009 | Mini Motorized Bike
Cycling Logo
113 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
