Question about Hitachi Televison & Video
TV goes into "power save" mode when turned on and then turns off
If you're playing with switches etc it'll stay on but as soon as you stop it will go into this mode and switch off
  • 179 Answers
SOURCE: ON/OFF button (red - off and on - green) flashing all the time
it is important to count the number of red flashes, if it is 5 then the lamp ballast board has failed, (part #1-468-798-14) if it is 4 then the optical block fan (# 178706511) is probably to blame, if it is 6 then the thermal fuse has gone bad..(# a1137954a)
Posted on Nov 29, 2007
Slinteriors
  • 8617 Answers
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
SOURCE: TV doesn't turn on
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
Posted on Feb 02, 2008
  • 317 Answers
SOURCE: Blinking Yellow light on a HD 65" DLP Toshiba TV
unplug all nite.
Posted on Aug 03, 2008
  • 905 Answers
SOURCE: rca 32v432t tv plays,turnsoff,turnson, and stays in autochannel search mode
your going to need to do a resolder of dry looking solder jobs and or poor solder jobs
this could also be your front control board , try disconnecting it and see if the tv stays on
it is possible that the sensor has gone bad or the crystal needs to be replace or worse the EEPROM
my rca 27 in was doing the same thing , i resoldered the board and it worked great for 7 months
so do a resolder of all suspicious solder and heated components
then let me know what happens
also what is your model # for your rca tv ?
also one of rca's kits for repair is some solder and paste , so that should tell you something in its self about rca repairs ( the solder with the paste is supposed to make it handel heat better )
please give a fixya rating so that if you need more help in your tv , I can continue to help you further , thanks
electech
Posted on Nov 08, 2008
Stop computer feom going into power save mode by itself.
You should be able to stop this by going into the control panel, select power options and change the settings for the hdd, sleep etc.
Just set them to 0 and that should stop it powering off.
May 22, 2014 | Dell OptiPlex GX260 PC Desktop
Tip
How to change or reset PS3 Video Display Mode
When you attach your Play Station 3 to an HD TV through an HDMI port, the Play Station 3 will ask you if you wish to switch to HD Mode.
However, if you decide to move it to another TV that is not HD compatible, you will get no picture because the Play Station 3 is “stuck” in HD (HDMI) mode.
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
That’s it! You can play your Play Station 3 again!
on Mar 12, 2010 | Video Game Consoles & Games
LG TV Goes Into Hibernation (I Think)
This could be two things 1- a power saving mode in the TV... go into settings on the TV, look for either "power save settings" or "energy star settings" go in and turn that off. 2- it could be a screen saving mode because the TV has lost signal...some HDDVR receivers such as Direct TV DVR etc...have their own power saving mode, after a couple our of inactivity, they turn off, which kills the signal to the TV...so the TV shuts down because it has no signal coming to it.... if that is the case, you need to go into the settings on your cable/satellite settings and also look for a "power save mode" or "energy star saving", and turn that off.
Mar 21, 2014 | Televison & Video
TWO VCRs stopped working.
Yes, try to look inside (not in play) when you hit fast forward or rewind--are the reels turning too slow or jerking etc?
It indicates a problem with the transport part of the unit---bad drive idler or even a slipping or bad belt or belts if used.
Dec 10, 2012 | Funai Televison & Video
LAMP KEEP BLOWING OUT. TOSHIBA 65 HM167
I had this same problem with my Mitsubishi it is when you have fast on mode set it pre warms the bulb to much. I turneed it off and now the bulb has lasted much longer Setting the Power-On Mode feature You can select either Power-Saving or Fast mode. If you select Power-Saving mode and you turn off the TV, it can take several seconds for the picture to appear when you turn on the TV again. Power-Saving mode saves more power than Fast mode. See "Specifications" on page 66 for details. If you select Fast mode and the TV is turned off, the TV will stay in Standby mode for several minutes (see Note below). If the TV is turned on from Standby mode, the full picture appears immediately. To set the Power-On Mode feature: 1 Press Y and open the Setup menu. 2 Highlight Power-On Mode and press c. 3 Press b or B to select either Fast or Power-Saving and press T. Note: If Power-On Mode is set to Fast and you turn off the TV, the following will occur for a few minutes: • The screen (lamp) lights dimly; and • The fans continue to run. This is a function of the Power-On Fast Shutdown mode and is not a TV malfunction. If you do not prefer this, set the PowerOn Mode feature to Power-Saving. When the Power-On Mode feature is set to Power-Saving, if you repeatedly turn the TV on and off in a short period of time, the useful service life of the lamp may be shorter than the average useful service life (- page 63).
this is from your manual not my Mitsubishi please rate this answer if you felt it was useful.
Feb 03, 2011 | Toshiba Televison & Video
TURN OFF LOCK. I AM IN MENU MODE, BUT WHERE IS THE ON/OFF BUTTON LOCATED?
Power on…Turn the POWER switch ON.
If the POWER switch on the backside of this recorder is
turned OFF, it is not possible to use any of the functions.
Turn the POWER switch ON before operation.
Power off…Turn the POWER switch OFF.
Standby Mode and Display Shut Off
If the recorder is stopped for 5 minutes or longer during recording or playing, it goes into
Standby (power-save) mode, and the display shuts off. To exit Standby mode and turn on
the display, press any button.
Locking a file keeps important data from being accidentally erased.
Locked files are not erased when you choose to erase all files from a folder.
In Menu mode selection... On, OFF
On: Locks the file and prevents it from being erased.
OFF: Unlocks the file and allows it to be erased.
Feb 02, 2010 | Olympus WS-100 Digital Voice Recorder
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
Stays in standbye and will only flash green (power on) twice before staying in standbye
The 6 inverter transformers on the bottom of the picture is the problem and what need to be tested.
Unplug the 6 wires that goes to the LCD screen. Use a multimeter to test for resistance from each output plug on the board. The one without the resistance is the bad one.
If this doesn't locate the bad one this way, Each plug should give out DC voltage if working properly. Test each plug for voltage.
The TV will automatically turn off in a couple of seconds like before. You'll have to keep pushing the power button to test each output plug for voltage.
Soon as you find the bad Inverter Transformer, just solder in a new one and the TV should work fine after that.
The part # for the Inverter Transformer is LTZ2PC0MS008.
Here's two places to get them:
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
Apr 23, 2009 | Televison & Video
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
Put camera on screen come on lens came out thwn power went off now power light wont stay on long enough lens wont go back in
maybe this works: turn your camera on in play mode (if you have play button press it to turn on camera) and if your camera hase a shoot-play switch select play mode and then turn your camera on.) repeat this until lens goes back. I hope this works...
Nov 01, 2008 | Samsung Cameras
Televison & Video Logo
194 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
