Question about Toshiba Satellite A105 Notebook
Need to find where the cmos battery is on my toshiba a105
  • NinaE May 11, 2010
    What problem are you experiencing ??
  • 85 Answers
You will have to open up your laptop and look on the motherboard. The CMOS battery looks like a watch battery it is silver and round and is usually covered by a rubber blue sleeve. I hope this helped solve your problem.
Posted on Jun 22, 2009
5 Suggested Answers
sonmarc07
  • 9 Answers
SOURCE: Step to how to replce cmos battery toshiba 1805-s254
Hi!
If you already found the cmos battery, then try to check its "rating" and size to accomodate inside the board. After that fix it as it should be.
Posted on Dec 31, 2007
knotbeerdan
  • 413 Answers
SOURCE: Hi, I need some help (BIOS locked)...
ok i found a couple more things...apparently you dont have to remove the battery.. I found this site that tells you two "jumpers" (solder squares) C88 i believe under the network card. But if you follow this link and follow the directions it will get you going again.
I don't know exactly at what stage you are at and i hope i didn't cause any trouble but this normally is how we take care of this problem. Unless once in a blue moon we come across one like this.
http://www.paralaptop.com/toshiba/fixing-bios-password-locked-on-toshiba-satellite-a105-s4014.html
Posted on Jan 17, 2009
  • 55 Answers
SOURCE: need to change cmos battery for toshiba laptop 1805-s274
look on back of laptop you will see some panels under panels you will see two little wires connected to mother board that's the cmos battery unplug it and change it
Posted on Mar 30, 2009
  • 1584 Answers
SOURCE: where is the cmos battery located on a toshiba
having stripped a few laptops, the entire laptop needs to be dismantled to access the CMOS battery. You do not say why you want to acces the battery.
Posted on Dec 03, 2009
How to reset my toshiba a105
reset your cmos? unfold the top cover then take out the battery for 10mins which switching on...
Jul 28, 2011 | Toshiba Satellite A100 A105 Series Laptop...
Clock will not set for correct time. Manually change but this does not work.
Most likely the CMOS (Bios battery), which is a small silver coin shaped battery on the motherboard needs changing. This maintains the correct time when the laptop is switched off. They last for up to 3 years then need replacing. (example in picture)
http://cgi.ebay.co.uk/CMOS-RTC-Battery-Toshiba-Satellite-A105-Series-/270751984156?pt=US_Batteries&hash=item3f0a136a1c
Be careful in changing the battery, If you have not done this before, refer to a computer repair shop.
Jul 14, 2011 | Toshiba Satellite A105 Notebook
Where is the cmos battery located on a toshiba satelite A105-s2131
There are several access panels on bottom of your laptop. These should have markings that designate what is behind each. CMOS battery can be either behind the hard drive panel or the memory card panel.
Alternatley, you can try this link to Tom's Hardware where someone is discussing how to do on a similar model. http://www.tomshardware.com/forum/247842-30-replace-cmos-battery-toshiba-satellite
Oct 11, 2009 | Toshiba Satellite 5005-S504 Notebook
I have a satellite A105 and When i turn it on it asks for password but I don't have the password. So how to I get past this to be able to use it again?
just remove the cmos battery
the bios stores the password and the cmos battery provides it power to store it
if you remove cmos battery the bios reverts to factory settings and the password is removed
cmos battery is different than the laptop backup battery
cmos battery is found inside the laptop case on the motherboard, you will have to open the laptop to remove the cmos battery
Sep 29, 2009 | Toshiba Satellite A105 Notebook
System time clock looses time
hello
here is a guide to disassemble the laptop
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Some motherboards have the battery soldered on ,i am not sure if yours is or not ,the batteries usually look like watch batteries.
you could always get a quote from an authorised toshiba support agent if you are uncomfortable opening the laptop.
The information on the hard drive will not be lost as it is saved on the hard drive itself.
May 11, 2009 | Toshiba Satellite A105 Notebook
Jan 17, 2009 | Toshiba Satellite A105 Notebook
BIOS Resetting...
Please open this link this will help you
http://www.thenetworkadministrator.com/biospasswords.htm
And dont forget to rate FIXYA if it didnt help please reply but dont rate any rating
Thanks
Regards
May 03, 2008 | Toshiba Satellite A105 Notebook
Cmos Battery
Look for the CMOS Battery under the keyboard, if not near the memory at the bottom of the laptop, there are screws to remove.
Hope this Fixya an idea where the battery is kept.
Feb 08, 2008 | Toshiba Satellite A105 Notebook
Lcd problem
Question- Is this the prompt that you get? "Password ="
If so, this is a known problem and you can make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. Use the following link to locate a Toshiba Authorized Service Provider.
http://pcrepair.toshiba.com
Have a super day!
R-
Nov 06, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
427 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
