Question about HP Pavilion dv4000 Notebook
Touchpad on toshiba satelite with vista will not function
Icon in taskbar but shows no response to touchpad looks to match another satellites set up
    Scholar:
  • 94 Answers
Try pressing the function key (fn), then TOUCHPAD.
Then, try re-installing your touchpad driver. On the toshiba's site's support/download.
Hope this helps! ^_^
Posted on Jun 22, 2009
Toshiba Laptop left click stopped wokring?
1) Examine your "Function"/"F" keys and look for a touchpad icon. If you find one, hold the "Fn" key and press the touchpad icon button to unlock the touchpad. Move on to Step 2 if your laptop doesn't support this feature.
  • 2) Plug a USB mouse into an open port on your laptop. Click the Windows "Start" button. Click "Control Panel" in Windows XP and double-click "Device Manager." Type "Device" in the search box in Vista and Windows 7 and click "Device Manager" from the results.
  • 3) Click "+" next to "Mice and other pointing devices." Right-click the touchpad and select "Enable." Your touchpad is now unlocked.
  • Feb 06, 2012 | Toshiba Satellite L505-S5966 Notebook
    Hello, my cursor (touchpad) is non responsive. Thanks
    I would check to see if it is turned off. On a Toshiba, you can press the Fn key and one of the special function keys to turn the touchpad on or off. There is an icon on the special function key to identify it.
    May 08, 2011 | Toshiba Satellite P105-S6197 Laptop
    Problem with the HP G60-235DX PC Notebook Notebook Touchpad won't scroll. (Synaptics) Previously it would scroll with no problem, then suddenly quit. How do I restore the function? Previous...
    Have you checked the settings of your synaptics? Usually there's an Icon on the taskbar for synaptics you can right click it and check if "disable touchpad if usb pointing device is present" is checked, if so uncheck it then your touch pad should work again.
    Here's a link for a step by step instruction though this is for windows xp but steps are the same. Hope this works for you:
    http://blueboxagency.com/helpdesk/?page_id=16
    Apr 10, 2011 | HP G60-235DX Notebook
    Volume Icon has disappeared.
    First, right click on the taskbar and select Properties from the right click menu.
    Alternatively, you can go to the Control Panel and type the word 'taskbar' in the search box from the upper-right side. Once the search results are loaded, click on the link that says 'Customize icons on the taskbar'.
    The Taskbar and Start Menu Properties window will show up on your screen. Here, go to the tab called Notification Area. In the System icons section check the Volume box and click on OK.
    The Volume Mixer icon will now show up in the notification area of your taskbar
    I hope that this information was helpful and thank you for contacting the experts.
    Jan 18, 2010 | Toshiba Satellite A65-S1362 Notebook
    The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
    The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
    http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
    Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
    ...or have your laptop repaired by a professional.
    Oct 09, 2009 | Toshiba Satellite A105 Notebook
    Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
    You might have inadvertedly disabled the touchpad.
    1. Press Fn + F9 to enable the touchpad.
    This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
    2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
    Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
    Change the settings if necessary.
    Aug 17, 2009 | Toshiba Computers & Internet
    How do I set touchpad settings to inop touchpad when USB wireless mouse is plugged in
    Some laptops have a Fn Key sequence to disable the touch pad. Look for the touch pad icon on your function keys (hand touching finger on a square). You can also go to the toucpad app by double clicking on the touch pad icon in the system tray and got to device properties to disable tapping - assuming issue is TPad interfering with typing
    Jul 25, 2009 | Toshiba Satellite U305-S5097 Notebook
    Scroll function on my Toshiba Satellite TouchPad isn't working
    I would go to this link and select your device and download the driver/software for your device. Try to reinstall the driver/software.
    http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download&cm_sp=Sitemap-_-Support-_-DriversDownloads
    Note:
    Fn-F9 is a hot key combination that will enable/disable the touchpad.
    Feb 14, 2009 | Toshiba Satellite Pro P300 Notebook
    Synaptics touchpad not working
    Have you looked at the Device Manager to see if there's a problem with the touchpad?
    Start -> Control Panel -> System -> click on Hardware tab -> click on Device Manager button. Do you see anything that indicates a problem with the touchpad?
    Also, you might want to check the BIOS to see that the touchpad is still enabled. I doubt that this setting would have changed, but it's worth checking. When you boot the computer you should see a message that says something like: "To enter setup press XXX" where XXX is the delete key or some other key. Once you're in the BIOS poke around to see if you can find the settings for the Touchpad. Different manufacturers use different BIOS' so I cannot tell you exactly where to look.
    Good luck.
    Dec 19, 2007 | Toshiba Satellite A20 Satellite A25 Series...
    HP Pavilion dv4000 Notebook Logo
    100 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
