Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Dirt not going in to the right "chamber"
The vacuum is collecting the dirt in the tube and not into the removable chamber. We can't find the directions anymore, and we can't figure out what may be wrong! It's practically brand new so we know that it doesn't need a new belt, and it shouldn't be super clogged anywhere. Any advice??
  • 10,865 Answers
Hello. i can help you. here is your link to a free replacement manual
http://www.eureka.com/owners_guide.jsp
also, check the hose to make sure that a foreign object isn't blocking airflow. Next, make sure the airflow switch is set correctly. Many models have a switch that changes the suction from the main vacuum to the hose attachment.
Posted on Jun 22, 2009
Bissell powertrak revolution dirt not going into cup
If the unit is not blocked between pickup and filter have a good look at the filter to see if air is passing through it---paper throwaway or foam filter the can be washed?
The ones that can be washed etc will have instructions right on them.
Nov 02, 2012 | Bissell 6591 Power Trak Revolution Bagless...
The fan housing tube is cracked just below the bottom clamp. How to replace
Its not to difficult, its just requires some patience. The first thing Ill recommend is removing the handle from the fan chamber tube, it should come apart pretty easily simply by turning the flange that threads it together. Watch the video I've attached it explains the removal of the handle. The bottom of the bag has a small metal spring clip that holds it onto the handle, just lift that off. Set the whole thing to the side. The cord will still be attached to the base, which is fine, its just easier to work on it when all that's set aside. You'll want to flip it over like you're changing the belt, remove the baseplate screws and pull it off. That'll expose the motor, belt, brushroll, fan chamber and dirt intake tube. Remove the belt, set it and the brushroll aside. On the right hand side there's one screw that holds the dirt intake tube on and two screws on the other side that hold the motor in. Remove them all. The dirt intake tube should slide out, set it aside. You'll need to pull the motor off the other side by wiggling it back and forth until it pops free from the fan chamber. Its just a friction fit. The chamber should be free, you'll need to just rotate it around to remove it from the base and it should come out. To reinstall the new one you just put it back in the opening on the base, refit the fan and motor back into it, hold the dirt intake tube on the other side and fit it back in gently. Oreck's don't have a rats nest of wiring or moving parts so just keep an eye on the screws and be patient!
Dec 19, 2017 | Oreck XL21 Bagged Upright Vacuum
Dirt devil jaguar pet vacuum - no power goes to vacuum
I've literally disassembled the ENTIRE vacuum. I got it for a dollar at the local goodwill with the intent on converting it into a dust collector for my mini workshop. As others have said. The suction is abysmal. I don't think it could beat a dust vac. And that's with just the motor hooked to dirt collector. No brush, no belt, no carpet adjusting. Just a motor, dirt collector and hose. Zero suction. Removed the hose, zero suction. Remove the dirt collector, solid suction. Dunno if the dirt collector is missing a part, but I doubt that based on other replies. I'm guessing all the holes in the red tube of top chamber are the issue. But I can't easily access it. I think I may end up cutting it open to try plugging some holes or some other modifications. But this vac is garbage in its original configuration
May 22, 2011 | Dirt Devil Vacuums
VACCUUM SEEMS TOOST SOME OF ITS SUCTION POWER
How often have you changed the filters in the vacuum?-- and when was the last time you did it now?
Obviously emptying the dirt collecting chamber OFTEN helps the vacuum--
but then in addition, there are several filters-- are they clean?
Pull them out, tap and otherwise shake the dirt loose from them, until they are clean--
(Compressed air is great for this-- but you might not have that nearby, right?)
Do yo have another vacuum that might help you clean up the filters?
Or-- maybe it is time to replace all the filters?
Let us know how successful your efforts on the above turn out.
Mack B
Dec 28, 2010 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Dirt is being trapped in the filter area instead of canister.
The canister has a filter as well. It needs to be replaced or cleaned. A damaged canister filter will feed dirt into the HEPA filter. (and the motor)
An improperly installed filter can allow dirt to bypass the canister filter and collect in the HEPA filter.
I suggest a new canister filter and then clean it carefully every week.
Here is a list of the filters for your vacuum.
Apr 16, 2010 | Eureka 5893AVZ Bagless Upright Cyclonic...
Clogged sweeper filters changed and hose cleaned, but no dirt collecting in the bag. I am no sure what do do next
You have a rubber flap in the dust collection bin that may have been pulled out causing the collection bin to close when vacuum tries to pass through. Try pushing the flap back in to see if that's the cause of your vacuum loss. To test if this is the cause try turning the cleaner on and feel the outlet leading into the removable bin to see if there is any air flow. If there is no air flow, unplug the vac and run a coat hanger through the inlet tube to find and clear any obstructions. Then take the vacuum outdoors, plug it in and turn it on to clear any dust or debris left in the vacuum chamber.
Mar 15, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
Dirt does not collect in container....collects in filter area
Small Filter at bottom of cannister may be clogged. Not letting enough suction draw dirt down.
Dec 22, 2009 | Eureka 5856BVZ Boss Bagless Upright...
No dirt is collecting in chamber and doesnt seem to be picking up
the hose is clogged. try sucking the dirt out with another vacuum (backward) If this doesnt work, you will have to disconnedt one or the other or both ends of the hose to remove the clog. this is a simple process.
thanks for your interest in FixYa.com
Dec 13, 2009 | Bissell 6594 PowerForce Bagless Upright...
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Jul 31, 2009 | Hoover Elite Rewind Bagless Upright...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
179 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
