Question about Boating
Why does my Minn Kota Vantage trolling motor act up.
I just bought a used Minnkota Vantage transom trolling motor(74Lbs) thrust. Took it out on my first time. It performed great for the first 7 hours.
Then the problems started, first I think I overheated it because I ran it on high for about a minute and it suddenly turn off and nothing would work( up/down or thrust). This stayed that way for approximately 25 minutes, then it turned back on when the switch was pressed. Everything went well for the next hour, then we could not get the motor to turn except in 1 position (10-15 degrees of turn and not the other 350 degrees) I thought that maybe it was the batteries but even the up/down would not work for a short time. A little while later the up/down worked but the trolling motor would only run in that same 10-15 degree direction. After charging the system after fishing, the same thing still persists. Any ideas?
Take the back cover off, two screws hold it in. Make sure you unplug the motor before doing this. There are a bunch of small different colored wires that come from the handle and connect to the control board via small bullet type connectors. Try unplugging each one of these and then plug them back together. I had a similar problem and it was bad connections on these wires.
Posted on Mar 05, 2010
  • 77 Answers
If this is a foot control model, try cleaning the connection where it plugs up. I have cleaned mine but I still have to fidget with it every time to get it to work right.
Posted on Jun 23, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
    Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
    Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
    https://www.minnkotamotors.com/
    Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
    I have a 74LBS thrust trolling motor that hasn't never in my opion worked right, I don't think its wired right to get the proper 24 volts, However I have took it loose and hooked it directly to 2 marine...
    Here is a picture of the wire connection for 24 volt. Compare to yours is it correct? If it is, I wish you listed make and model I could of sent you the right picture diagram of you motor. Use this picture as a starting point. Test the wires through the motor testing for 24 volts. Again if I knew make and model I could show you exactly were. Last if voltage is correct all the way through. The motor is the last thing to tear down. If the brushes or armeture is damaged in anyway, or manufactured wrong, it would lead to power loss.
    Nov 18, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
    Minnkota trolling motor prop removal
    remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
    Apr 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
    How does the minn kota 65 all terrain run on 24
    You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
    Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Trolling Motor will not run
    Hi!
    For starters, here is a schematic:
    Endura 30
    Check to see if there is appropriate voltage getting to the switch (with an ohm meter).
    You can (please do this carefully) disconnect the battery positive and negative as well as the motor red and motor black wires and connect the Batt positive to the motor red and the Batt negative to the motor black. If the motor runs, the switch is faulty. If it doesn't then I suspect the motor needs looking at.
    Best of luck!
    Mike
    Feb 06, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Model 35 24lb thrust transom trolling motor not getting power
    It might help to view drawings at http://secure.northlandmarine.com/MinnkotaTillerSteering.html.
    The spring loaded items are brushes. They carry current to the rotor/shaft/impeller causing them to spin. I have two Model 35s. One failed after a couple hours of use. The other was given to me because it did not work. Both suffer from water getting into the motor and causing corrosion and sticking brushes. Someone on another site commented that this was a common problem for Minn Kota.
    Jul 17, 2008 | Minn Kota Endura 30 Freshwater Transom...
    Boating Logo
    492 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
